Quadra-Jet / Epoxy ??
Old Dec 3, 2005 | 05:13 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Quadra-Jet / Epoxy ??
I will attempt to include a picture of a similar carb / My 72 base Coupe runs fantastic and has had the timing / carb / advance set according to all the "good stuff" as posted on the forum. It still idles TOO RICH no matter what. I have heard to EPOXY 'something" on the underside of the carb.
Can someone identify the "spots" on the included pic that need to be sealed with epoxy ?
Old Dec 3, 2005 | 05:43 PM
comp's Avatar
comp
do you mean the well plugs
Old Dec 3, 2005 | 05:46 PM
fotyfobravo
I think so but I'm not sure......whatever "can leak" at idle causing it to idle too rich.
Old Dec 3, 2005 | 06:56 PM
BigBlockk's Avatar
BigBlockk
First you need to get the base plate off of it.
In the photo above the well plugs are the four red dots at the top. The plug to the left (accelerator pump well) leaks sometimes as does the fuel inlet plug at the bottom of the picture. It's a good idea to do them all while your doing. These are plugs with soft metal peened into the seams. They plug access holes used for drilling passages when the carburetor was manufactured.
By the way, if you're going to be working on this carburetor you really need one of these.
http://www.ecklers.com/product.asp?...5&dept%5Fid=224
BigBlockk
Later.....
Old Dec 3, 2005 | 07:01 PM
fotyfobravo
Thanks BigBlockk....I printed your pic and will use when I do it !
Old Dec 5, 2005 | 04:35 PM
comp's Avatar
comp
Old Dec 6, 2005 | 12:26 PM
lars's Avatar
lars
Before you bother with the epoxy, remove the carb from the engine, fill the float bowl with fuel, and set the carb up on some spacers on your workbench. See if fuel drips out of any of the spots identified by BigBlock. If nothing drips, there is no need to epoxy. It's actually rare that the Q-Jet will leak - the leaky plug thing is a bit over-rated. So check it before you spend the time doing it - I'll bet you'll find no leaks...
To Quadra-Jet / Epoxy ??
