Seat installation question
Old Dec 9, 2005 | 10:14 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Default Seat installation question
Hi all,
I am at it again this weekend...
I am finally putting the seats in and wanted to know... do I cut the rug for the seat bracket to fit under or bolt right to the floor with the rug underneath? I have seen it both ways but I am thinking cut the rug so the bracket is actually touching the body...
Old Dec 9, 2005 | 10:26 PM
big_G's Avatar
big_G
Cut a flap the way Chevy did it. If you were to bolt through the carpet, it might pull the weave apart.
Old Dec 9, 2005 | 10:31 PM
LYLE's Avatar
LYLE
In front the factory made a flap about 2"wide and 2 1/2 " deep hinged ( not cut) in the front to get at the bolt then folded it back down. The back was just a hole in the carpet. A pencil solder iron makes a nice hole in back but it smells. Works good to install the rubber plugs as you have a nice round hole to put the plug through.
Old Dec 10, 2005 | 02:36 AM
Z-man's Avatar
Z-man
Here's a shot of the stock carpet front and rear. I did what quite a few folks suggested and used carb studs to mount the seats. Now they lift out and back in without having to fish for the holes...
Old Dec 10, 2005 | 11:04 AM
sly vette's Avatar
sly vette
Carb studs. I like it.
Old Dec 10, 2005 | 02:12 PM
Mr.Gearhead
Fishing for the bolt holes are a pain... I will try the stud method. Thanks for the pics and advice... I can't wait until this body off rebuild is completely finished... It is going to be a blast to drive... everything is all new... WAHOOOO
Old Dec 11, 2005 | 01:03 AM
Edzred72's Avatar
Edzred72
Not only that...but longer mounting bolts are needed, especially if you have underlayment.
Eddie
To Seat installation question
