Frame Question???
Old Dec 10, 2005 | 09:31 PM
BlackRocket's Avatar
BlackRocket
Default Frame Question???
I pulled the body off the basket case vert today and the frame is solid with a little surface rust. There is however a joint on both sides of each side rail just in front of the mid-crossbeam with the exhaust openings. There is a flat rectangular piece of metal welded on the inside 45 degree slope on these side rails at the same place as well.
Is this normal or is this a patch....where the entire front-half of the frame was replaced?
Old Dec 10, 2005 | 10:06 PM
sly vette's Avatar
sly vette
Need pics.
Old Dec 10, 2005 | 10:23 PM
BlackRocket
Don't know how to post pics. To better describe, both side rails have a "step" with a weld about half-way back on the sides. Is this normal or should the outside flat portion of the side-rails be completly smooth front to rear.
Old Dec 10, 2005 | 10:38 PM
fl_rider's Avatar
fl_rider
Default I hope this helps some...
I use PhotoBucket
www.photobucket.com
It's free!!
You can upload pictures there and then link to them in your posts.
On photobucket copy the IMG link and paste it into your post here.
It will look like this but show a picture instead:
[IMG]www.photobucket.com/name/picturename.jpg[/IMG]
Here is one that works:
Chris B
Old Dec 10, 2005 | 11:37 PM
big_G's Avatar
big_G
Yes, smooth. But get pic. up a.s.a.p.
Old Dec 11, 2005 | 01:47 AM
BlackRocket
Default Attempting photo upload
Old Dec 11, 2005 | 01:48 AM
BlackRocket
Default Picture of "patch plate"????
Old Dec 11, 2005 | 01:51 AM
BlackRocket
Default Description of pictures....
The first picture shows thew weld vertically on the side and top of the frame.
The second picture shows the "patch" plate in the inside portion of the frame.
Both sides are the same????
Old Dec 11, 2005 | 01:52 AM
JonnHeather's Avatar
JonnHeather
It looks like that frame has been sectioned. Nothing wrong with it if it is done right, but they didn't even finish off the welds on the outside. Hopefully they sleeved it...
Old Dec 11, 2005 | 01:57 AM
BlackRocket
Yeah, I think you are right. Looks like it was sectioned. I measured a couple of "x" dimensions and they were right-on. I am such a meticulous person I may have to save my pennies and order a SRIII tube frame for my basket case.
What do you think I can get for a rolling frame like this with little rust, brakes, rear trailing arms/susp., front susp, and steering arms. All used of-course.
Old Dec 11, 2005 | 11:05 PM
72LS1Vette's Avatar
72LS1Vette
Many of us in the North East would KILL for a frame that clean, weld or not. Unless you're doing a NCRS restoration, you could just grind the weld down and powdercoat the frame as long as the rest of it is in good condition. I don't know the value of a rolling chassis, but unless the suspension has been rebuilt with new bushings, etc. and the trailing arms are in A1 shape I would guess that the rolling chassis wouldn't be worth too much more than the bare frame.
Rick B.
To Frame Question???
