My Differential code is wired?
Old Dec 11, 2005 | 04:37 PM
Augustus's Avatar
Augustus
Default My Differential code is wired?
I have on my Differential this code
OA 2 03 W7E1
The first two are defeinitely OA
and I checked these numebers like 10 times LOL
I can't even tell what gear or anything.
Anyone know how to decipher this?
Thanks eveyone.
Old Dec 11, 2005 | 04:54 PM
LYLE's Avatar
LYLE
OA is a 76-77 3.08 203 is the julian date W=Waren Motive 7= 77 E= Eaton Positraction unit 1=1st shift
Old Dec 11, 2005 | 09:48 PM
Augustus's Avatar
Augustus
I'm horrified but relieved to find out this... I'm getting this code from a 69 BB car... (Apparently a BB car) LOL
So any other way to confirm that this is indeed a 76-77 rear end and not a 1969 rear end? LOL
I checked codes for the 1969 model year and the only thing close I was thinking that was listed was AO which is a 3.70 gear but it reads OA !!! So I was thinking maybe the GM factory made a mistake when inputting the code and by mistake stamped OA instead of AO... LOL
Any possibility... NOT LOL
I am flabergasted and shocked... Tell me more guys... You guys are my Freaking Saviors!!!
Old Dec 11, 2005 | 11:53 PM
LYLE's Avatar
LYLE
It could be stamped backwards real easy at the factory. I am not sure that 7 is the year as the numbers and letters don't read right. Many rear ends have been exchanged at corvette shows and by rebuilders.
Old Dec 12, 2005 | 07:52 PM
Vette Dent's Avatar
Vette Dent
You could pull the cover and count the teeth-
2.73 - 41 and 15
3.08 - 37 and 12
3.36 - 37 and 11
3.55 - 32 and 9
3.70 - 37 and 10
4.11 - 37 and 9
You will at least now for sure what your ratio is.
Old Dec 13, 2005 | 03:03 PM
Augustus's Avatar
Augustus
Thanks Vette Dent
Is there any way to determine for sure what model year that rear end is?
Other than those OA 2 03 W7E1 codes
Anything on the side or anything else? LOL
Old Dec 13, 2005 | 04:49 PM
GTR1999's Avatar
GTR1999
If you go to that post I have going in tech I just did a 69 BB diff. The date code is cast into the housing on the drivers side. The internal posi case and spider gears are different between 69 and 76. It may/may not have the older little sq window vs the larger tear drop rear opening. The spinder would be 10-18's vs the better 10-17's. That's lot of work for a date code though. If it runs ok and you like the gear leave it alone otherwise you're going to be doing more work then you need to.
Gary
To My Differential code is wired?
