Won't Start !!
Old Dec 12, 2005 | 07:04 AM
8DVETNUT's Avatar
8DVETNUT
Default Won't Start !!
Turned the key to the first position all lights, fans work. 2nd position
( to turn it over) and everything stops, doesn't turn over, no nuthin!
It was runnin great where to start ?
Old Dec 12, 2005 | 07:39 AM
Jclgodale3's Avatar
Jclgodale3
Bad ground somewhere
Old Dec 12, 2005 | 08:48 AM
rihwoods's Avatar
rihwoods
Check your main harness connection at firewall...mine did that and was corroded..just cleaned it and the turkey fired right up...
Old Dec 13, 2005 | 08:32 PM
8DVETNUT's Avatar
8DVETNUT
Thanks for the replies guys, sorry for the newb questions, I've got 12 volts on the starter side of the harness and down at the starter, grounds seem ok. Could a starter ( 25 year old delco) just go out with no warning?
Old Dec 13, 2005 | 09:14 PM
vabeachvette's Avatar
vabeachvette
about 2 months ago my ac delco starter died, not a single warning, push started it to get her home and put a replacement in, started right up.
Old Dec 13, 2005 | 10:06 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Not to be a smart azz but make sure the car is in Park or in Neutral. I was at a gas station and a guy came over and asked me if I had jumper cables and could help him. I went over to help him out and he tried it and nothing. I asked him to pull it down in drive and put it back in park. Viola`, the car started.
Just a thought.
Old Dec 13, 2005 | 11:02 PM
jlaw68's Avatar
jlaw68
nuetral safety switch
Old Dec 13, 2005 | 11:44 PM
A72COUPEDT's Avatar
A72COUPEDT
Maybe a bad battery cable...negative side.
Check it where it attaches to the frame.
Mine was triple the size from corrosion.
Try it...good luck.
Dave
To Won't Start !!
