suspensions for hot rods
Old Dec 18, 2005 | 11:38 AM
chevy69's Avatar
chevy69
St. Jude Donor '08
Here is what I did on my 38 dodge biz coupe, and 2 previous projects. I have a mig and plasma cutter so this helps a little. I get the suspension kits from a company called Street Rod Engineering out of Lake Havasu, AZ. Tom is the guy to ask for. He was very helpful with questions during the installation process. I have used them on a 46 Ford Tudor, a 47 Ford pickup, and my current 38 dodge project.
http://www.streetrodengineering.com/
here is the 38 dodge biz coupe
http://photobucket.com/albums/b203/a...eengine004.jpg
here is the '47 pickup
http://photobucket.com/albums/b203/a...t=B02_0002.jpg
Old Dec 19, 2005 | 08:52 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
chevy69....thats a sweet set up.....did you have to remove a crossmember to do that or did it just get installed behind the original crossmember? what kind of suspension did the car have before a transverse spring or two paralllel springs? thanks bob
Old Dec 19, 2005 | 09:01 AM
moosie982's Avatar
moosie982
Hey Bob, Do you know if the frame needs to be boxed to use the bolt in crossmember ? I was thinking about the same kind of deal for my '40, along with a pair of parallel rear leafs, any idea about what rear you will be using? but I think it'll have to wait until I get this Corvette project on the road, the '40 still drives (or would if I got a new battery), good luck to ya on the '37 they are definately cool
Peace,,,Moosie
Old Dec 19, 2005 | 09:18 AM
bobs77vet's Avatar
bobs77vet
Peace,,,Moosie
we should ask jslu75 i think he installed the bolt in one....i don't think the frame needs to boxed to do this but it is obvioulsy a good idea especailly if you are dropping in a SBC....i will be using a new rear axle with a parallel leaf design....it will probalby be a GM one since thats the easiest for me to get....is your 40 frame like mine? if it is when we make up the new frame nis section crossmembers we can make up a second set for your car....not sure where you live in NY but if its close you can drive down and pick them up. we are planning to do the crossmembers out of tubing kind of like what Pete and Jakes sells....
Old Dec 19, 2005 | 10:25 AM
moosie982's Avatar
moosie982
Hi Bob, thanks for the reply, yes I am almost positive that the frames are the same, or at least very similar, from all the companys that sell reproduction frames they all list '35 to '40 as being the same ? What exactly kind of frame sections are you talking about ? I live up here in N.Y. about 30 miles or so (northwest) from where N.Y., N.J. and Pennsylvania meet, nearby the Deleware River corridor. I think that boxing would need to be done if only to strengthen the frame , after all we are dealing with some old iron here. The main reason for me wanting a bolt in crossmember is that in that way I'd be able to do almost all of the work at home without having to farm out any of it without the the boxing part. I dont have a welder nor do I weld, my mentor was gonna teach me many years ago but got upset with me when I lit the torch, and thats as far as the welding lessons (of any kind) got, he was a patient man . Yep, the Mustang II front suspensions may be outdated, but in light of what they are replacing are light years ahead in design, handling and ride quality, besides thats the reason for the Corvette,,, handling. Peace,,,Moosie
Old Dec 19, 2005 | 10:33 AM
Ganey's Avatar
Ganey
... besides thats the reason for the Corvette,,, handling. Peace,,,Moosie
For those that drive fast & hard.
Here's something I came across awhile back:
By Don Meyer
"I have built approx 40 rods over the last 40 yrs. I have used both Must II(both factory, TCI & Hiedts) & Camaro/Nova on most. I also have installed these on many customer cars before retirement. I also believe I was the first to us a Must II IFS.
From this knowledge base, the Camaro is a nicer IFS. Better handling w/Globalwest upper A arms, heavy duty sway bar available is available & w/power steering it just plain has a better fill to it. You can also us late model El Caminos/Mc's....etc, which are narrower." Don Meyer
Old Dec 19, 2005 | 11:16 AM
bobs77vet's Avatar
bobs77vet
.... What exactly kind of frame sections are you talking about ?
Sullivan county?
i'm thinking it would look something like this:
http://www.peteandjakes.com/parts/35FordIFS.htm
Old Dec 19, 2005 | 12:25 PM
Corey_68's Avatar
Corey_68
Not bad, in our shop we use Fatman Fabrication on all the Street Rods we build. Been very impressed w/ their products and the customers love the ride/look.
http://www.fatmanfab.com/
Old Dec 19, 2005 | 12:38 PM
moosie982's Avatar
moosie982
Hey, Yep, Sullivan County, the "good side". but the tourists are starting to re-discover us, Narrowsburg, Lake Huntington, Woodstock 1969 site, Bethel. Yes, that frame that you directed me to would be deluxe, back when I was rich I seriously considered it, damn,, shoulda done it, now that I'm a brokester again maybe I just oughta concentrate on the important things,,,,,,,,,Kids first, cars second, the son graduates this year (if he can squeak by in math etc.) and the daughter will graduate next year, (no problem with her,,, an excellent student) both speak of college. Good to dream,,, me,, not the kids, God bless 'em they will go to college if they want,, me I'll continue to dream about my Ford.
Peace,,,,,Moosie
Old Dec 19, 2005 | 01:53 PM
bobs77vet's Avatar
bobs77vet
moosie when i get around to building the crossmember if you want me to build two at the same time i will....most of the work will be in figuring it out, the fabrication part should be easy and fun..
Old Dec 19, 2005 | 05:44 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I did install the bolt in Mll from CE.They told me the frame did not need to be boxed with their unit.I wanted the bolt in for the same reason that Moosie does.Don't know how to weld and wanted to do it myself.The CE crossmember was really easy to install.I installed TCI leaf spring rear susp.Bob did you get the pics I sent you?
Old Dec 19, 2005 | 06:19 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
Hey Bob, I'll attach a few more pics here that show before and after shots. Both the '47 PU and the '38 Dodge had parallel leafs. The dodge had a fairly difficult frame to prepare for the crossmember, the '47 ford pickup was relatively simple. I cut/ground all the old stuff off (including the old Xmembers) before welding in the new components.
here is the '38 dodge after I stripped the front end off and pulled all the old drivetrain, etc... out:
http://photobucket.com/albums/b203/a...odgework13.jpg
Here is the front end welded in - note the inside of the frame and all the cutting/welding that had to be done. Fords are NOT this difficult. I had some help on this part of the job.
http://photobucket.com/albums/b203/a...odgework33.jpg
Here is what I started with on the '47 pickup - a real bubba special. I had a lot of cutting, grinding, etc.. but cleaned it down to the bare frame:
http://photobucket.com/albums/b203/a...t=B47_0096.jpg
Here is the frame after I boxed it in and welded the crossbember in (before bolting on all the suspension). I did this one entirely on my own.
http://photobucket.com/albums/b203/a...t=B37_0147.jpg
Old Dec 19, 2005 | 07:52 PM
  #33
bobs77vet's Avatar
bobs77vet
jslu75 i got the pictures thanks, they help alot, that frame is awsome, hope mine looks that good...
chevy 69 that looks really good, what tolerances do you have to be within when you weld everything up? are we talking .000s or are we talking 1/16". Glad i don't have to make the decision tomorrow, because they all look really good...what do you use as the reference ? the front crossmember? what did you weld it in with Arc or Mig?
Old Dec 19, 2005 | 09:30 PM
  #34
chevy69's Avatar
chevy69
St. Jude Donor '08
I use a mig (Millermatic 175) with gas. I pretty much taught myself to weld a few years ago by practicing and watching others. The tolerances are not in the .000 range, but a lot of measuring, double checking and triple checking is a good idea. I tacked it in then went back and completed the welds once everything was in place and checked out. You'll get plenty of welding practice in while you are boxing the rails in as well. It's been 18 months, but as I recall, I made some reference marks on the frame before getting started (these were spelled out in the instructions). I think it referenced the old spindles, and the Xmember sat centered on those marks. I made phone calls to Tom Pierce at SRE before I welded everything in just to go over my process and double check everything. Getting the frame level before you start measuring/welding is also very important. Good luck on your decision
Old Dec 19, 2005 | 10:02 PM
  #35
bobs77vet's Avatar
bobs77vet
thanks, i'm thinking i may upgrade my Lincoln migpak 125 a couple of notches if i decide to go with a weld in one. i'm thinking the small Lincoln just may not give the penetration i need. And yes i agree with you after boxing in about 60 feet of frame rails I should have sharpened up my welding skills.
