Gost flames
Old Dec 17, 2005 | 07:13 PM
algleason's Avatar
algleason
Default Gost flames
Do ghost flames have to applied as part of an on going paint job, or can they be added to an existing paint job? If so, how is that done?
Al
Old Dec 17, 2005 | 07:21 PM
big_G's Avatar
big_G
Either way is acceptable. though I incorporate them with a full repaint if possible, (you won't feel the flames). You can prep the old finish to accept the new artwork, then clear the refinished area, preferabaly the complete panel.
Old Dec 17, 2005 | 10:59 PM
Brandywine's Avatar
Brandywine
With 3 stage paint the metallic base coat(s) are sprayed, followed by the ghost flames. The candy coat(s) are applied, followed by several coats of clear. On mine, the ghost flames are done in a color that is very similar to the candy coats. I also have shaded flames that are several different colors, predominately blue, orange, and dark silver. These colors show up alot more under the red candy. The ghost flames are hardly visable unless you come up to the paint or see it from an angle. Here is a couple of pics. Hope this helps.
Old Dec 17, 2005 | 11:29 PM
comp's Avatar
comp
i like them so you bearly see them
Old Dec 18, 2005 | 08:51 AM
Brandywine's Avatar
Brandywine
The orange and yellow metallic flames are barely visable under the candy red, you have to be close to see them. The other colors are what show up as the shaded flames.
Old Dec 18, 2005 | 06:15 PM
algleason's Avatar
algleason
How do you get the images on the post? I haven't been able to get it to work yet.
Old Dec 18, 2005 | 09:03 PM
Brandywine's Avatar
Brandywine
See the following...
http://forums.corvetteforum.com/show...es&forum_id=31
Old Dec 18, 2005 | 09:56 PM
enkeivette's Avatar
enkeivette
I'm under the impression that Ghost Flames are faint and part of the original paint job, under the clear coat. That's what makes them Ghost like.
Old Dec 19, 2005 | 09:41 AM
comp's Avatar
comp
one of the ways i like them , is they are shot with a little pearl in the clear
Old Dec 19, 2005 | 10:28 AM
Brandywine's Avatar
Brandywine
To Gost flames
