Flat spots on tires
Old Dec 18, 2005 | 06:27 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Flat spots on tires
First of all does this happen when a car is left for an extended period of time?
Old Dec 18, 2005 | 06:48 PM
Gordonm's Avatar
Gordonm
It used to but with modern radials it is not a problem.
Old Dec 18, 2005 | 07:09 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
My car sits from November to April, it's fine
Old Dec 18, 2005 | 08:13 PM
1972warship's Avatar
1972warship
I'm not disputing this, but I have read that it is good to up the tire pressure to around 44lbs, which is supposed to help prevent flat spotting. Of course you need to lower it when driving the car.
Old Dec 18, 2005 | 08:16 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When I would let my 96 set in the garage for a while I would notice it would ride rough for a little while. Shortly the ride would be smooth again. I had the car for about 5 years I guess and put about 5000 miles on it so it spent some time setting around.
Old Dec 18, 2005 | 08:18 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
On the older bias ply tires this was an issue, but not with todays radials
Old Dec 18, 2005 | 09:30 PM
694speed350's Avatar
694speed350
my cars are rough for a short amount of time but they smooth out .
Old Dec 18, 2005 | 10:00 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
happened today.
Old Dec 18, 2005 | 10:20 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
We get them in our mud truck. 40 inch tires are to expensive in radials just to be driving in the mud.
To Flat spots on tires
