carpet
Old Dec 19, 2005 | 12:29 AM
ddaveyboy@home.com's Avatar
ddaveyboy@home.com
Default carpet
Hey guy's...I want to put new carpet in my wifes 77 corvette. We still have leaks when it rains hard..so I would prefer not to put down any felt underlay. Anybody got any suggestions on what brand , loop style etc. ect. And ball park price range would help as well
Old Dec 20, 2005 | 03:55 PM
James1970's Avatar
James1970
Check out Corvette Central, Ecklers, Zip, or other Supporting CF members.
I only have one question, Why put in new carpet if you still have a leakage problem? Seems to me it would be a good opportunity to fix the problem while to old carpet is out.
No reason to throw good money after bad (although some on this forum would argue that that's all we do ;-)
Good Luck,
James
Old Dec 20, 2005 | 05:15 PM
Scottys78's Avatar
Scottys78
Good Luck,
James
Old Dec 20, 2005 | 05:17 PM
kona's Avatar
kona
Don't put the cart before the horse fix the leak first!
Kona
Old Dec 20, 2005 | 11:01 PM
rws.1's Avatar
rws.1
willcox for carpeting
Old Dec 23, 2005 | 11:48 AM
ddaveyboy@home.com
Default carpet
Sorry guys..I should have been more descriptive on troubleshooting the leaks in this car. I have installed a complete set of high end wheather stripping ,new windshield & caulking ,sealed the firewall cowl ,adjusted the side windows for optimum sealing , adjusted the t roofs for optimum sealing, cleaned out the firewall/ cowl drains. Appaerently 77's are prone to leaking in the fresh air vent area & short off removing the fenders to check out that area & seal up the debonded area....You get the picture. Unless anybody has any other ideas on how to seal up that area..I am stuck with it.
Old Dec 23, 2005 | 04:34 PM
1Z87L8's Avatar
1Z87L8
are you sure the fresh air door is closing?
on the 78 i recently bought the guy was going
because he couldnt stop the leaks.
i pulled the kick panels to inspect the birdcage area i
found the air door on pasengers side stuck wide open.
dont know what caused it but after i freed it up and
sprayed some lube it seems to be functioning perfect now.
have not had it in weather yet but when i washed it i didnt find
any water inside so hopefully that was my problem.
good luck
Old Dec 23, 2005 | 07:57 PM
ddaveyboy@home.com
Yes sir.....replaced the seals on them as well
Old Dec 23, 2005 | 08:56 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i recently put new window in my house and used this spray expandable foam that stays flexible.....it does not "bow" the window frames....i'm thinking of using that in between the scuttle frame and the fiberglass body....it would not break anything and would expand enough to fill cracks...
Old Dec 24, 2005 | 10:59 PM
ddaveyboy@home.com
Hmmmm...Interesting idea.
You would really have to make sure it didn't get anywhere near the fresh air vent doors though.
Good thinkin
To carpet
