1982 Corvette Dead Battery
Old Dec 29, 2005 | 10:56 AM
The Alaskan's Avatar
The Alaskan
4th Gear
Default 1982 Corvette Dead Battery
My 1982 Corvette's battey keeps going dead, I charge the battery and a few days later the battery is dead. Any idea why this is happening? Is this a common problem with the 1982 Corvette. Any help is welcome.
Thank you
The Alaskan
Old Dec 29, 2005 | 11:11 AM
startwith80vette's Avatar
startwith80vette
you may have a short somewhere that is a draw on the battery, or it may just be time for a new battery
Old Dec 29, 2005 | 12:43 PM
markdtn's Avatar
markdtn
Some possible areas are compartment lamps, horn relay, electric fan, a relay possibly?
Old Dec 29, 2005 | 12:48 PM
Toms82's Avatar
Toms82
Default dead battery
Hi,
My 82 does the same thing. I gave up looking for the cause and installed a battery post disconnect switch. Not a perfect solution, but it works. Regards,
Tom
Old Dec 29, 2005 | 01:35 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Charge your battery, remove the cables and see if it still goes dead. If not, it's a short somewhere, if it does, it's the battery.
But I'd install a set of quick battery disconnects either way.
Old Dec 29, 2005 | 01:38 PM
another-user's Avatar
another-user
the batter in my 69 always dies too, im positive theres a short some place. i just pull the cables off the battery when im not driveing it and all is fine.
Old Dec 29, 2005 | 05:14 PM
Jims79's Avatar
Jims79
My 79 & 66 do the same thing. kill the battery in a few days. Like many others gave up looking for the problem and ran out of $$ tring. So I installed the green battery disconnect **** on both. No more dead batterys. Problem is still there I know that.
To 1982 Corvette Dead Battery
