Help!!!! Lifter Noise
Old Dec 29, 2005 | 02:41 PM
gr8t73's Avatar
gr8t73
Default Help!!!! Lifter Noise
When I drive my 73 L-48 for 30 minutes or more at around 75 to 80 mph and then bring the car to a stop at idle I hear one or more of the lifters tapping. This stops after approximately five to ten minutes at idle. I can drive the car around town (low rpm) all day long and the problem never occurs. What going on?
Old Dec 29, 2005 | 03:30 PM
rihwoods's Avatar
rihwoods
May be carbon....Listen at valve covers with long screw driver...you may at least isolate issue....mine did that once autocrossing ...we misted water down carb at idle 1500-2000 rpm and the noise went away..carbon in my case...
Old Dec 29, 2005 | 03:43 PM
big_G's Avatar
big_G
Another cause may be the oil is thinning when hot, causing a little more lifter bleed-down. Maybe additional lifter pre-load, (1/4 turn down more ) may help.
Old Dec 29, 2005 | 04:06 PM
jaggeedfire's Avatar
jaggeedfire
My SUV is doing the same thing. Except when im at idle it sounds like its going to come through the valve cover. Let it sit and the noise goes away. I think mine is carbon as the egr seems to be sticking throwing the check engine light. I dont want to pull the covers as this thing has 6 coil packs overhead and quad overheads with no leaks what so ever.
Nick
Old Dec 29, 2005 | 09:29 PM
gr8t73's Avatar
gr8t73
Default Thanks for the info. guys
I think I'll try both misting water down the intake & some additional preload on the lifters (1/4 turn). BTW I did find that it is the # 7 intake lifter.
Old Dec 30, 2005 | 02:01 PM
Boofers's Avatar
Boofers
Exhaust leaks often sound like valvetrain noise, a tiny little ticking sound that seems to be more pronounced under load. Check the tightness of your exhaust manifold bolts, look for any little black marks where exhaust might be puffing out. Header gaskets are known for leaks, so if you have headers you may even want to pull the gaskets out and look at them. Some simple things to check compared to digging into your engine.
Old Dec 30, 2005 | 06:43 PM
gr8t73's Avatar
gr8t73
Default For Certain No Exhaust Leak
It is a pronounced tapping noise and it only occurs under the conditions I described earlier.
Old Dec 31, 2005 | 05:20 PM
chris75stingray's Avatar
chris75stingray
the same one ticks on mine once in a while but stops when the engine is warmed up
Old Jan 2, 2006 | 09:51 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Exact same situation here!
Old Jan 3, 2006 | 08:55 PM
gr8t73's Avatar
gr8t73
Default Adjusted lifter lash on all cylinders!!!
I adjusted the lifter lash on all cylinders and drove at 75 to 80 mph for twenty five miles brought car to idle and no tapping noise. Hopefully problem doesn't come back. One concern, the lash adjusting nut on #7 cylinder is much easier to turn than others. Should I replace the nut? Is it possible the lash adjustment nut is backing off over time?
Old Jan 3, 2006 | 09:08 PM
big_G's Avatar
big_G
Yes and Yes
To Help!!!! Lifter Noise
