oil pressure
Old Dec 29, 2005 | 07:03 PM
694speed350's Avatar
694speed350
Default oil pressure
what should the oil pressure be in a 69 350/300 engine?
Old Dec 29, 2005 | 07:48 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
I think the rule of thumb is 1 psi per 100 rpm is safe, but for your particular car, I'm not sure. If you're running the high pressure pump, it may be between 50 and 80 psi all the time.
What are you seeing now?
trw
Old Dec 29, 2005 | 09:47 PM
wb6mfw's Avatar
wb6mfw
Normal guage reading should be 35 to 40psi.
Bill
Old Dec 29, 2005 | 09:51 PM
redc3's Avatar
redc3
yea its another myth that youve got to have all this pressure. to much pressure can be a bad thing
Old Dec 29, 2005 | 10:44 PM
randyredleg's Avatar
randyredleg
My '80 is 40 at idle and about 60 at cruise.
Old Dec 30, 2005 | 03:26 PM
694speed350
thanks for the answers guys. only had the car for a little over 3 months. still checking it out to see what needs to be done to it. the oil pressure is between 35-40 . just wanted to be sure the lower end was ok.
Old Jan 1, 2006 | 08:50 AM
1971corvette's Avatar
1971corvette
I would feel safe with those readings
Old Jan 1, 2006 | 09:05 AM
mstanton's Avatar
mstanton
What about high pressure? What can cause and what are the dangers?
Old Jan 1, 2006 | 09:36 AM
71redskin's Avatar
71redskin
i was runnin 60* before i replaced my valve seals and run seafoam through the crankcase. i'm now at 40 and happy with that... dont know if it was the seafoam or theseals but i'm happy to see it back to normal
To oil pressure
