Car dollies - worthwhile?
Old Jan 1, 2006 | 01:35 PM
Vette Gator's Avatar
Vette Gator
Default Car dollies - worthwhile?
I saw a set of car dollies for $45 yesterday and wondered whether they were worthwhile. The car is currently up on jackstands and takes up all of our two-car garage. I was thinking of putting it on a set of car dollies so I can roll it to the side and let my wife park her car back on "her" side of the garage (a very popular idea with the missus) when I'm not working on it.
If you use (or have used) dollies, what's your opinion? How easy is it to get the car on and off them to put it back on jack stands or back on the wheels?
Old Jan 1, 2006 | 01:38 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
They work great as long as your floor is level. If not the car can roll by itself, and it might not be where you parked it. But I have a set and they work fine.
Old Jan 1, 2006 | 02:50 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I have been wanting to get a set of these myself.Where did you see a set for 45 dollars?
Old Jan 1, 2006 | 03:02 PM
PRNDL's Avatar
PRNDL
$45 for a set of 2, or 4? Different quality can make a big difference. I bought mine from Harbor Freight. Cheap, but not top quality. It can be a real struggle to move the vette around. I have to crawl underneath and twist the wheels with a wrench to make them point in the right direction. All in all, it's really not too bad... but sometimes I wish I had just paid more money for something that is easier to push around the garage.
Old Jan 1, 2006 | 03:53 PM
Red 69's Avatar
Red 69
I bought my first pair at a Big Lots store for about $45 a pair a few years ago and then a pair from HF for $49 a couple years ago. I liked the first pair so much, I had to do it to all four wheels. Orginally, my idea was to put a floor jack under the front crossmember with the dollies at the other end and roll it that way. I like my dollies and they appear exactly like what is sold in the auto parts cataloges. When they are not under the car tires, I use them to make my stick welder and heavy parts mobile. If you are planning to buy and have time, wait for them to go on sale. They roll purdy easily on my epoxy painted concrete floor and can recommend them @ 4 for $100.
You only gain a couple inches of floor clearance and you put it on jack stands the same if they were not there. I often use two jacks on the front and rear frame corners at one time.
Old Jan 1, 2006 | 06:19 PM
Vette Gator
I saw them for $45 at the local TSC. I should have looked at the box more carefully to see whether that was each, per pair or for four dollies. I'll check it out in the next couple of days.
Old Jan 1, 2006 | 06:58 PM
Vet76te's Avatar
Vet76te
I have a set that I LOVE, but I paid a lot more than $45 for them. Mine have a foot brake on them. It's a little flip type bar that you can move with your foot. It locks one of the wheels, which keeps them from rolling. Also, make sure the set you're buying is wide enough. I have seen narrow sets, and the wide tires of a Corvette would not work on them.
One more thing,...if you get a set, make sure you keep your tires aired up correctly. If you allow a tire to go flat, they can sometimes flip off the dollie when you go to roll the car. Then the dolly flips up and cracks your car or puts a dent in the rocker trim.
However, I wouldn't have a garage without a set,...myself.
Old Jan 1, 2006 | 07:07 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Because the entry to the house is barrier-free, the garage floor slants noticeable toward the driveway - which slopes down to the street. Probably not a good choice for me.
Old Jan 1, 2006 | 08:00 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
we just have the regular small slope in the garage and if you leave the car out of gear it will slowly drift backwards..... i would think that for those dollys to work really well they would need to be decent quality, yo don't want to have crawl around and point the wheels
Old Jan 1, 2006 | 09:02 PM
Blue 74's Avatar
Blue 74
It has been my experience that Harbor Freight has a pretty good no hassle return policy. I'm gonna get a set of 4 next time they go on sale and try them out. If they suck then I'll be returning them.
Old Jan 1, 2006 | 09:30 PM
Glass Act's Avatar
Glass Act
I know we all try and save a few dollars at times. A friend has, what I'll call a cheaper set of dollies and they are an effort to move his car. I paid $245.00 for 4 dollies made by Car skates. I can move my cars with one hand without any effort. You may find that the cheaper ones will not work as well and dislike them, not to say there aren't some good ones out there at a lower cost.
Another way to look at it, our Vettes were expensive new in whatever they were built compared to other cars, and here we are today still with the best cars built, way ahead of their time. Remember, you get what you pay for
My 0.2 only
Old Jan 1, 2006 | 09:47 PM
Panhead's Avatar
Panhead
I also have the 'skates' and one hand is all it takes to move the car, the bigger ball bearing casters make it an easy operation.
Old Jan 1, 2006 | 09:51 PM
PRNDL's Avatar
PRNDL
Glass Act, Are these the ones you have? Carskates?
http://www.carskates.com/spec.htm
I see they are $245 Canadian, but $180 US. I would seriously consider buying a set if they would make the vette easy to move around the garage.
Old Jan 1, 2006 | 09:56 PM
Glass Act's Avatar
Glass Act
Yes those are the ones I have, the place is less than an hour away from me. So I drove down and picked up 2 set to save shipping cost. I really like them for ease of moving the cars, compaired to some my friends have.
Old Jan 1, 2006 | 10:05 PM
dfellinger's Avatar
dfellinger
My son in law bought four from Harbor freight last week for $90 for four. Put them under his car the same day and the car is real difficult to move. I bought a set at the same time for my 71 vert and think I will take them back based on how difficult it is to move his Mustang.
Old Jan 1, 2006 | 11:19 PM
Allen_396's Avatar
Allen_396
I bought a set a couple of months ago. I researched it some, and settled on these that are linked below.
They have the ball bearing axles, and are wide and deep enough for my Vette tires. I'm very pleased with them. I can move the Vette around the garage with minimal effort.
I bought the 12" wide deep set with BB (ball bearing) axles.
http://www.tireskate.com/
http://www.tireskate.com/ts12deep.htm
Old Jan 1, 2006 | 11:45 PM
Old Vet's Avatar
Old Vet
Default Go Jaks
I tried the cheaper Harbor Freight models, pain to have to jack up car difficult to roll around in garage so I returned them & stepped up an bought a set of gojaks. They fit around each wheel & then have a foot jack built into each unit that you raise the car with & then roll around like on ice any direction...only concern would be size of car tires and of course you pay for what you get, I paid $425 for a set of 4 used ones, I have seen some cheap repros but stick to the real deal..
To Car dollies - worthwhile?
Old Jan 2, 2006 | 07:39 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
These tops for the tireskate look interesting, too:
http://tireskate.com/st.htm
Old Jan 2, 2006 | 08:26 AM
Vette Gator
I really appreciate all the feedback. I think I'll take a pass on the cheap ones and keep a lookout for some better quality dollies.
Old Jan 2, 2006 | 11:21 AM
Scooter70's Avatar
Scooter70
Mine came from http://www.car-dolly.com/. I have no problem pushing the car over the 3/4" gap between the concrete slabs in my garage by myself. Like others have said above, they're more expensive than the Harbor Freight ones but they're quality.
