Code Breaker Help!
Old Jan 2, 2006 | 10:33 AM
hawgn68's Avatar
hawgn68
Default Code Breaker Help!
Any of you guys with the books and/or knowledge know what a HAH suffix on a 327 means? The engine code is T0406HAH. Google searching only gives me cynical laughs (hah, hah, hah) Thanks in advance.
Jimbo
Old Jan 2, 2006 | 06:56 PM
Duke94's Avatar
Duke94
Only book I have is "Corvette by the numbers" and it doesn't list a "AH" code. According to the book, first letter is Assembly plant ("T"=Tonawada), next 2 numbers=Assembly day, next 2 numbers=Assembly month, Next letter=Motor division, and last 2 letters are suffix for "the intended application for that engine in the model year that it was built". 8 characters total. It does say that beginning in 1970 MY, the engine suffix code increased to 3 letter code. Based on this info, the engine must not be used in a Corvette. You'll need the book "Chevrolet by the numbers" to find out exactly what it was used in.
Old Jan 2, 2006 | 08:47 PM
palazzopl's Avatar
palazzopl
try mortec.com they have all the eng numbers
Old Jan 2, 2006 | 10:37 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it says 1966 327....
http://www.chevy-camaro.com/chevy-ca...es.asp?group=4
Old Jan 3, 2006 | 10:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Only Corvette big blocks were produced at Tonawanda. All the small blocks came from the Flint, Michigan engine assembly plant. Your Tonawanda small block is not a Corvette engine. My records do not list an HAH code, but HA indicates a 66-68 327 passenger car replacement block.
To Code Breaker Help!
