solid u joints
Jan 2, 2006 | 06:59 PM
solid u joints
does anyone have a part number for the spicer solid u joints? I found some that were heavy duty but were not solid.
Jan 2, 2006 | 11:07 PM
Call Toms Differentials. 802-611-4197. Also see tomsdifferentials.com
Jan 2, 2006 | 11:54 PM
Part#s for a 71 Vette
Solid Spicer SPL25-1X U-Joints for Drive Shaft
Solid Spicer SPL30-1X U-Joints for Half-Shafts
These are Spicer Life Solid U-Joints. Call a local drive-shaft shop they should have them in stock and have them install, can save you time and prevent you from damaging the flanges and yokes. Don't ask me how I know. My local shop only charged $7.50 per u-joint to swap out.
Jan 3, 2006 | 04:45 PM
The Spicer #'s I have are 5-799x for the 1/2 shafts, the Driveshaft could be 1 of 2 sizes.
5-790x is for the early automatics and 75+ 4 spds.
5-785x is for the early 4 spds. It is smaller then the 790x.
Here's a picture of the tool I make too.
Gary
Jan 3, 2006 | 08:17 PM
I think there are new new cross reference numbers for Spicer Life solid U-joints.
SPL 22-1X for old 1310 (used on early shark and C2 drive shafts)
SPL 25-1X for old 1330 (used on later 71 on I believe drive shafts)
SPL 30-1X for old 1350 (used for half shafts)
Jan 4, 2006 | 12:59 AM
thanks for all the replies, Gary, does that tool just keep the flange from twisting?
Jan 4, 2006 | 02:44 PM
Yes it holds the flange secure so it doesn't bend if you press them on/off.
Jan 4, 2006 | 03:21 PM
OK, so whats the difference between the SPL series and the 700 series u-joints??
...redvetracr
