Two Holes
Old Jan 8, 2006 | 06:43 PM
El_Cid's Avatar
El_Cid
Default Two Holes
This is the shot looking into my battery compartment, and those two holes go straight through and you can see the ground from them, but obviously not at this angle.
are those meant to be there? or did someone drill for no reason?
Old Jan 8, 2006 | 06:59 PM
Justus Becks's Avatar
Justus Becks
I think it's for the battery, if you battery leaks
Old Jan 8, 2006 | 07:03 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
also back in the seventies, we still had batteries that you had to check & fill the water level. So if there was a spill of anykind, these holes allowed it to drain.
Old Jan 8, 2006 | 07:10 PM
cptkirk32's Avatar
cptkirk32
They were also used for the vent tubes off the battery.
Kirk
Old Jan 8, 2006 | 07:11 PM
694speed350's Avatar
694speed350
Old Jan 8, 2006 | 07:18 PM
redc3's Avatar
redc3
shrader valves for air shocks were probably on your car at one time
Old Jan 8, 2006 | 07:31 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Kirk
They were only used for the two battery vent tubes.
Old Jan 8, 2006 | 08:55 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Old Jan 8, 2006 | 09:05 PM
cptkirk32's Avatar
cptkirk32
Sorry, I should have said only and not also,,,oooopppss
Kirk
Old Jan 8, 2006 | 09:45 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
What year is this on? Is it your 82? The hole to the left is the drain, there should be, not a plug, but a tube type thing. The other hole is where the ground battery cable enters the compartment. Look at where the cables come in, that ain't right. One cable is piggybacked with the other. Both cables should enter the compartment individually. Also, 82s had sealed batterys, no drain tube like earlier C3s.
Mike
Old Jan 8, 2006 | 11:38 PM
El_Cid's Avatar
El_Cid
Yeah ,she's an 82.
And as i take it, its ok to seal these holes up?
Old Jan 9, 2006 | 12:02 AM
KapsSA's Avatar
KapsSA
Originally Posted by El_Cid
Yeah ,she's an 82.
Nah, leave em open, won't hurt anything. May want to flush out the crud some day.
Mike
Old Jan 9, 2006 | 01:05 AM
standup's Avatar
standup
......And as i take it, its ok to seal these holes up?
Interesting question, since the battery is in the cabin, if there's a hydrogen gas build up, where does the gas go if it isn't vented???? Could be a potentially dangerous situation.......
I've never seen vent tubes on a battery before....are these peculiar to Vettes ?????
And are they available to buy today...other than Delco ???????
Just curious........
BTW, I don't think these holes have anything to do with air shocks, as the holes are too big for a Schrader valve (think bicycles)...and who would want to pump their air shocks in that tight space ??????
To Two Holes
