noob question....
Old Jan 9, 2006 | 09:12 PM
76mike's Avatar
76mike
Default noob question....
I pulled the hose that connects the passenger side of the carb (quadrajet) to the air filer, and it runs a lot better. What is this and do I need it?
Old Jan 9, 2006 | 10:00 PM
76vette1's Avatar
76vette1
I think your talking about the heat riser vacuum line on a stock air filter. The line runs from the carb to valve under the air filter and then from the valve to the baffle on the fresh air intake duct. Basically, this directs warm air from around the exhaust manifold into the carb to help a cold engine warm-up faster. Once warm, the baffle should open to allow cold air in.
Old Jan 9, 2006 | 10:38 PM
76mike's Avatar
76mike
Ok... but after I took that off the engine ran a lot better. What is my issue here? What should I do?
Old Jan 9, 2006 | 11:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
probably you need to examine all of the hoses they may have been all hooked up wrong over the years...if the car started to run better what comes to mind is that something was restricting air flow....
Old Jan 9, 2006 | 11:17 PM
76mike's Avatar
76mike
I guess I'll check the hose... could it be a bad heat riser? I mean it raises the idle and increases acceleration a lot... something is up.
Old Jan 9, 2006 | 11:18 PM
bobs77vet's Avatar
bobs77vet
yeah it could be aheat riser it also could be that everyone on of your hoses is hooked up wrong.....thisis not uncommon
Old Jan 10, 2006 | 12:02 AM
76mike's Avatar
76mike
hahaha ok can you explain which ones should go where? Sry if that is difficult... at this point I'm all for leaving it off though and I don't want to do that if I don't have to. Probably helps explain my 8mpg.......
To noob question....
