power antenna
Old Jan 13, 2006 | 11:49 AM
Toms82's Avatar
Toms82
Default power antenna
Hi,
I've heard that power antennas from other GM car lines will fit a Vette.
Does anyone know if this is true? If so, which GM car?
Thanks,
Tom
Old Jan 13, 2006 | 11:55 AM
kona's Avatar
kona
I don't know about other GM antennas fitting but I replaced mine with an aftermarket and it works fine. I also added a hidded toggle switch so i can keep the antenna from going up when I play a CD works great.
Kona
Old Jan 13, 2006 | 04:17 PM
cab's Avatar
cab
i am interested in a power antenna myself. how do you get to it.
Old Jan 13, 2006 | 04:20 PM
kona's Avatar
kona
Go to the left rear corner of your car and look up above the muffler. Sometimes you can change it without removing the muffler and sometimes you can't. I changer the one on my 80 w/o taking the muffler off.
Kona
Old Jan 13, 2006 | 04:23 PM
70sgeek's Avatar
70sgeek
Metra PW 22 is a good a/m replacement - comes with an assortment of install parts to guarantee the fit...
Old Jan 13, 2006 | 04:32 PM
ORLY's Avatar
ORLY
7th Gear
Old Jan 13, 2006 | 04:55 PM
audiec's Avatar
audiec
I just installed mine over my christmas vacation. I had the tank and rear bumper off so it wasn't much of an issue. I bought mine on ebay for $45, mounting gromet barely fit over the origional body hole. I'm happy with it...
Audie
Old Jan 13, 2006 | 05:32 PM
stingr69's Avatar
stingr69
I know that some of the parts are quite interchangeable. The drive cable that fails frequently fits a TON of other GM applications and is still available cheap from Delco parts dealers. If the motor still works but the antenna won't go up or down you probably need that repair kit. I have done a couple of them myself and it is pretty easy.
The power antenna assy itself is harder to come by and has been discontinued for many years. There is a repro out there but I would not trust it personally.
Hope this helps.
-Mark.
Old Jan 13, 2006 | 05:43 PM
jdp6000's Avatar
jdp6000
I purchased a used Delco out of a 94 Cadillac. I used the trim ring off a 1997 Mercury Sable. The Delco was a touch shorter then factory but longer then aftermarket.
Jim
Old Jan 13, 2006 | 08:35 PM
c3 in hawaii's Avatar
c3 in hawaii
I used a aftermarket one from carquest, no problems with installation, it actualy lined up with the original bracket, grommet fit well. I guessi got lucky on this one.
Old Jan 13, 2006 | 08:42 PM
Blue 74's Avatar
Blue 74
Originally Posted by Toms82
Hi,
Thanks,
Tom
Years ago salvage yards had parts interchange manuals. Don't know if they still do but it might be worth checking.
To power antenna
