Oil 'survey'....strokers
Old Jan 13, 2006 | 04:29 PM
firstimer's Avatar
firstimer
Default Oil 'survey'....strokers
Just wondering what you guys are runnin'.....multi-vis? straight 30 or 40 or ???????????????? Synthetic or dino??? '73 with a 383 I got a few mos. back, built in '97, 'bout 10K on it, I put Mobil 1 in and wondering if I hadn't of just stayed with a straight or multi-vis dino.
Thanks.
p.s. dealing with an intake leak now.
Old Jan 13, 2006 | 04:35 PM
zwede's Avatar
zwede
Always run Mobil1 10W-30. I've got 50K miles on the motor and it is still spotless inside with leakdown below 10%. I'm a believer.
Old Jan 13, 2006 | 04:42 PM
Gordonm's Avatar
Gordonm
I have run Mobil 1 in my motor after 200 miles of dino oil for break in.
Old Jan 13, 2006 | 05:10 PM
GT1981's Avatar
GT1981
Default Oil survey
I switched to Mobil One 10W30 for my 1981, stock 350, with 30,000 miles about two months ago. so far, so good
Greg
Old Jan 13, 2006 | 05:15 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Catrol GTX 10W40m 10,000 miles and uses no oil
Old Jan 13, 2006 | 05:19 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
syntheic! Larry
Old Jan 13, 2006 | 05:43 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Straight 30 weight but just have about 1,000 miles on new rebuild.
Old Jan 13, 2006 | 10:02 PM
carl a's Avatar
carl a
i was told today ,, by builder ,,to run moble 1 ,,,,10 w 30 in my 383 ,,,but not until i get 1000 miles on it. first i gotta get 100 miles at 50 mph,steady! also said if extremely hot outside and going to be hard on car(road tour ect) can run 15 w 40 or 20 w 40 mobil 1 but normally 10 w 30 mobil 1 should be fine,,, i never used synth. oil before so ,, im a first time myself,, and to change after 3,000 miles..also look into moroso # 22460 (small block chevy)racing type oil filters for peak filtration 27 microns no back flo
Old Jan 13, 2006 | 10:10 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have about 3k miles on my rebuilt motor and have not switched to synthetic yet..... although i did buy the castrol dino/syntec blend for this next oil change.... i may just go with the blended mixture and change the oil every 1k-2k or 6months whichever is longer
Old Jan 13, 2006 | 10:17 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
I currently run Amsoil 10w30 in everything I own (even my mower). After the 383 gets broken in it will go straight to Amsoil as will the tranny & all greases. I like Amsoil, but others are just as good. Synthetics rule!
Old Jan 14, 2006 | 12:05 AM
glen242's Avatar
glen242
Valvolene Racing 10W-30 for the first 1000 to 1500 miles, because of the higher zinc. Then will change to Castrol GTX 10W-30.
I change oil twice a year and put on about 1000 miles in a good year. With the alleged extended drain intervals (milage) with synthetics, I would be changing oil every 5-6-7 years. Don't like that.
Old Jan 14, 2006 | 10:50 AM
zwede's Avatar
zwede
Even with synthetics they recommend changing atleast once a year.
Old Jan 14, 2006 | 12:02 PM
firstimer's Avatar
firstimer
Thanks to all for your responses. Just got to wondering about leaks I've read about in other threads 'possibly' related to synthetics. Maybe just B.S.?
Old Jan 14, 2006 | 12:50 PM
C3 Stroker's Avatar
C3 Stroker
I run Royal Purple 10w40 synth.....when I made the switch, I had to re-torque the intake manifold to hold in the "slippery" oil.
Old Jan 14, 2006 | 01:04 PM
Red73's Avatar
Red73
I use Mobil 1 in my stroker.
Old Jan 14, 2006 | 03:31 PM
redc3's Avatar
redc3
switched to mobil 1 after first 1000 miles. i run synthetic in all my cars, mowers, trannies, rear ends. even syn brake fluid in my DD toyota
Old Jan 14, 2006 | 04:31 PM
gq82's Avatar
gq82
Quaker State 10W/30...the only oil I've used in every car I've owned for the past 30yrs.....never had an engine break down.
Old Jan 17, 2006 | 09:33 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks.
You can take a look at this recent update to AMSOIL's motor oil comparision and see that in general, all the synthetics outperform the semi-synthetics and petroleum based oils.
Comparative Motor Oil Test
When running a mult-viscosity oil, keep in mind that an oil requires viscosity improvers, or VIs, to increase the spread. As these VIs breakdown, the oil will go out of grade, particularly the cold grade. Mineral oils require more VIs than synthetics do. A good 10w30 synthetic, e.g. not a group III synthetic, requires very little VI to meet the 10w standard. So, if you go with a multi-vs mineral oil, I would stick with short oil change intervals.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Oil 'survey'....strokers
