71 headlight door open warning sw/light
Old Jan 18, 2006 | 07:35 PM
67VetteMan's Avatar
67VetteMan
Default 71 headlight door open warning sw/light
When the headlights pop-up and are on, is the headlight door open warning light supposed to stay on the entire time or does the light extinguish after some time??
Thanks,
Old Jan 18, 2006 | 07:37 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The light is supposed to extinguish when the lights reach the full up position. The problems lies in the switches themselves. Lots of times they are broken. I have a few pics of what they should look like. Let me find them and I will post them.
Old Jan 18, 2006 | 07:42 PM
Eddie 70's Avatar
Eddie 70
With the headlight raised.
With the headlight down.
Old Jan 18, 2006 | 07:53 PM
67VetteMan's Avatar
67VetteMan
Excellent - I though those were the switches but wasn't sure until now.... thanks.
WOW - just looked at Ecklers - $26.99 EACH!!!!!!!! jeez....
Old Jan 19, 2006 | 03:05 PM
67VetteMan's Avatar
67VetteMan
Seems the switches are ok and the little activation button depresses correctly. Here's the issue, the driver side button depresses correctly when the headligh is raised, the passenger side - though raised - doesn't come into contact with the piece that wil depress the button. With the passenger side raised what I see is more like the picture you posted of the headlight down - but the contact is off by about 1/4" or so.
Sounds like an adjustment? but where? to the actuator screw to allow the mechanism to come up more? I'm not quite sure what to adjust now....
Old Jan 19, 2006 | 03:39 PM
theandies's Avatar
theandies
There is an adjustment in your future. It's been such a long time since I messed with my light I can help you on where and what needs adjustment. I think you would adjust it by lengthening the actuator rod. You can do what I did and tie-wrap the button down. (Read Bubba). My passenger side switch's threaded part broke off and my switch is just hanging (I did tie-wrap it out of the way). I'll eventually get a new one some day to get the Bubba tag off my shirt.
Old Jan 19, 2006 | 06:21 PM
67VetteMan's Avatar
67VetteMan
I'll mess with it. I suppose the springs have to come off then the cotter pin holding the actuator rod pin in and remove the rod itself. Then loosen the actuator arm by the turning it counter clockwise on the threaded rod - lengthening the rod and forcing the headlamp up higher... then put the whole thing back together.
Those springs look like a pain to get off then back on though...
With all that said - sounds like Bubba had a good idea with the tie wrap...
Old Jan 19, 2006 | 06:52 PM
sly vette's Avatar
sly vette
Default Damn
I got a Bubba and didn't even know it till I read this thread. OK I got the location of the switch, now where is the indicater on the dash?? By the way I have a '69.
Old Jan 19, 2006 | 08:39 PM
JIMS1970VETTE's Avatar
JIMS1970VETTE
I got my switches through The Last Detail (about $17.00 each, I think) and I had to put in a shim on mine to get the lamp to go off at the fully raised position. Good luck
Old Jan 19, 2006 | 08:42 PM
67VetteMan's Avatar
67VetteMan
Indicator on the 71 is on the center gauge bezel, passenger side, upper right corner, lower lens - where there are 2 lenses together - Upper lens says "Door Ajar" and the lower one says "Head Lamps". The pair are to the right of the Water Tempo gauge.
Ecklers description says "1969-74 Door Ajar Warning Lens"
Old Jan 21, 2006 | 09:16 AM
sly vette's Avatar
sly vette
To 71 headlight door open warning sw/light
