frame off progress
Old Jan 19, 2006 | 01:25 AM
gator79's Avatar
gator79
Default frame off progress
I finished the front suspension, now all that is left for the front is the steering system and new brake lines. I mounted up my 17 x 8 rims and they really look wide. most people on the forum are running 17x 8 rims with no problems. it is just really hard to tell with the body off. give me some reassurance here that they will be ok. I ordered some 255/45/17's for the front.
Old Jan 19, 2006 | 02:00 AM
Star79's Avatar
Star79
You're getting way too much done. Meanwhile I haven't even SEEN my car in two months. I think you should take it all apart again and "finish off" the factory welds on the frame
Old Jan 19, 2006 | 02:07 AM
Retro78's Avatar
Retro78
nice work...you wont want to drive it
Old Jan 19, 2006 | 02:58 AM
Muddywaters's Avatar
Muddywaters
Looks very nice....great work!
Old Jan 19, 2006 | 06:47 AM
gator79's Avatar
gator79
NOT
Old Jan 19, 2006 | 07:04 AM
fl_rider's Avatar
fl_rider
Default Wow!!!
That is so cool!!!
I am excited for you. You are making fantastic progress.
Chris B
Old Jan 19, 2006 | 07:53 AM
kidneyboy's Avatar
kidneyboy
Looks great!
Old Jan 19, 2006 | 08:35 AM
Jims79's Avatar
Jims79
Nice work. I wish I had the time, talent and money to do mine.
Old Jan 19, 2006 | 10:12 AM
worship79's Avatar
worship79
Old Jan 19, 2006 | 10:37 AM
NHvette's Avatar
NHvette
Nice job .... but be careful the front doesn't slide off that jackstand.
Old Jan 19, 2006 | 10:53 AM
82MDVette's Avatar
82MDVette
I'm pulling the body on my 82 and was wondering, how do you disconnect the fuse panel from the wiring harnesses at the firewall?
I have taken out the couple of long bolts that hold it to the firewall. However, I do not want to pry the units apart to hard for fear of breakage.
Old Jan 19, 2006 | 11:12 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default looking good
Dont forget to upgrade those brake & fuel lines to stainless and get some new stone shieds for the lines too. Ita a detail that you wont regret with all the hard work you are doing
tim
Old Jan 19, 2006 | 11:33 AM
gator79's Avatar
gator79
tim
the lines are ordered along with braided steel brake hoses. what stone shields? my lines only had the armor around them
Old Jan 19, 2006 | 11:36 AM
sweethence's Avatar
sweethence
Default stone shielding
the spring like wire that wraps around the lines you called it "armor" it keeps stones from damaging the lines and helps keep kinks from forming. sounds like you in like flynn.
keep the pics coming i am inspired
Old Jan 19, 2006 | 11:56 AM
steves_77vette's Avatar
steves_77vette
DON'T DO THAT! You do not need to disconnect the fuse panel to pull the body. You need to disconnect the ground points of the frame to the body and engine that are made in the front around the headlights and at the starter motore and then the rear lights and that's about it. But do not, I repeat, do not disconnect the fuse panel.
Old Jan 19, 2006 | 11:57 AM
steves_77vette
You're fine. Withouth the body on, it's very hard to get perspective of how things like tires will look, etc.
Old Jan 19, 2006 | 08:57 PM
Star79's Avatar
Star79
You may already know this, but I've read (here on the Forum) that you shouldn't do final-torque on your control-arm bolts until you have weight (engine and body) on them. Also I have read to NOT tighten the rear leaf-spring attaching bolts (center ones) until you have the body on.
Old Jan 19, 2006 | 11:55 PM
gator79's Avatar
gator79
that may be the case with rubber bushings, but all mine are poly. someone correct me if I am wrong
Old Jan 20, 2006 | 03:47 PM
Scottys78's Avatar
Scottys78
looking good.........nice work you have done
To frame off progress
