Tank sticker
Old Jan 20, 2006 | 12:18 AM
tekcor's Avatar
tekcor
7th Gear
Default Tank sticker
I have located the gas tank sticker on my 73 and want to know if I remove it to make a copy and find the options will if affect the value of the car in any way...Anybody able to help me with this????
Old Jan 20, 2006 | 04:43 AM
hunt4cleanair's Avatar
hunt4cleanair
There is always a dabate on what to do with a tank sticker...once you find it! Remove it or leave it. The thinking is that once removed from the tank...it lessens the verifiability that that particular tank sticker came off of that particular vehicle...or something like that.
It's suggested you take pictures of it in place...and leave it there. That way you can show it has one and that's its still in place. The value is that it is there and documents the vehicle options as it departed the factory floor.
An additional consideration is that once you've removed the tank...these things are brittle, difficult to read if on a high-mileage car and the glue could cause difficulties in removal.
But now 73 was the first shark model to sport the new landscape style build sheet and therefore is always of interest. If you do photos post and let us look! good luck and keep us posted.
Old Jan 20, 2006 | 09:40 PM
tekcor's Avatar
tekcor
7th Gear
Default No luck
Well I tried to get in there with a camera to get some photos but there just is no room. I can read some of it with a mirror but think the only way to really see what it says and get photos I would have to drop the tank.. So you may have to wait a while to see any photos unless I remove it.... ... Thanks
Old Jan 20, 2006 | 10:10 PM
gator79's Avatar
gator79
mine on my 71 is vewry brittle and glued on. I don't think it would come off without destroying it. I want to repaint the tank what should I do?
Old Jan 21, 2006 | 02:30 AM
tekcor's Avatar
tekcor
7th Gear
Wish I could advise you but I too am looking for answers... Mine at least is in very good shape.... The page is complete and still has the little holes on each side where it feed through the computer. It appears on each side in the center to be glued for about 1 inch with a very hard plastic type glue...The big question is to leave it there or try to take it off, without damaging it , to verify the options and then replace it... Anybody got options??????
Old Jan 21, 2006 | 02:38 AM
Greg's Avatar
Greg
Just another Corvette guy
I razored mine off. I figured, why leave it there to deteriorate more. No one can see it when it's on the tank so how do they know if it's even there? I really don't think it will diminish your value to remove it, clean it and keep it in a plastic envelope. If I remove any of my gas tanks I usually remove the sticker and save it at the same time. The new owners always seem to appreciate it.
Just go easy with the blade
Old Jan 21, 2006 | 02:43 AM
another-user's Avatar
another-user
kinda wish i took a picture or something of mine before it got burned off when the tank had some holes welded up. although there wasnt a whole lot left of it from what i remember.
Old Jan 21, 2006 | 07:27 AM
gator79's Avatar
gator79
I was thinking about putting that wide clear packing tape over it to hold it together than try to get it off with a razor blade
Old Jan 21, 2006 | 12:54 PM
tekcor's Avatar
tekcor
7th Gear
That would work... They make a wide plastic that they use to cover books with ... That would at least hold it all togeather while you attempt to get it off... Good luck..
Old Jan 21, 2006 | 12:59 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Mine is out. I'd rather have it sitting in my house then turning to dust under the car. As much as it may lessen the value by not being on the car, I'd rathe have it that way. Eventually it will be faded and brittle to the point where it will not be verifiable anyway. It's the lesser of two evils in my opinion.
Old Jan 23, 2006 | 11:22 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I carefully removed mine with a parts grabber. I immediately scanned it and photocopied and enlarged and enhanced it. The print seems very delicate and any rubbing will erase it. You can usually make out most everything if you have a valid option list available to compare to. I was lucky, the spot I really wanted to see was the delivery dealer.
Old Jan 23, 2006 | 05:19 PM
harrin's Avatar
harrin
take a pict and leave it on the tank
Old Jan 23, 2006 | 08:53 PM
PRNDL's Avatar
PRNDL
With a 73 your vin is going to identify the engine, so I think you are ok to remove and try to preserve the tank sticker. I think the problems really surround a bigblock, say a 435 hp from 67 - 69 where people are afraid the car was originally smallblock converted to bigblock. Once you remove that tank sticker you create suspicion as to authenticity, but with a 72 or later it is less of an issue (because vin tells engine)
Old Jan 24, 2006 | 09:39 AM
firstimer's Avatar
firstimer
Default Here's mine...
Since my '73 was modified when I bought it, I wanted to know for sure just what options were actually on it new. Got it out through the gas door. Don't think it would have been any better with the tank out, maybe, but sure BRITTLE!!!
http://img.photobucket.com/albums/v616/freewayrandy/tanksheet.jpg[/URL]
sorry 'bout the link, hope it works, had a prob. posting the pic...bein' a 'puter dummy.
Old Jan 24, 2006 | 09:46 AM
firstimer's Avatar
firstimer
Default maybe this will work...
AHA!!!!
Old Jan 24, 2006 | 09:50 AM
firstimer's Avatar
firstimer
Default something else...
found out what tranny and rear diff. ratio for sure and dealer where car originally sent to.
Old Jan 24, 2006 | 10:09 AM
early shark's Avatar
early shark
There are differences in the type of tank sheets on '68 thru '72 cars.
A major change occurred in 1971. Those of you with sheets attached for 1968, 1969 & 1970 will probably fair a little better than those with 1971 & 1972 sheets.
For any rare high hp model, I would definitely recomend removing this document if your lucky enough to have one and it's readable. It need to be archived in a acid free document holder, otherwise it will continue to deteriorate.
To Tank sticker
Old Jan 24, 2006 | 10:28 PM
tekcor's Avatar
tekcor
7th Gear
Well I thank you all for your info on the tank sticker... I guess tomorrow is the day as I am going to take it off and take some pictures of it...What do you mean by an acid free document holder??? When I get it off I would like to protect it as well as I can...I will try to get some photos posted as soon as I can
Old Jan 25, 2006 | 02:25 AM
early shark
Go to any hobby/craft/scrapbooking store, they should carry it. It is usually used for old photographs to lay on in albums.
Old Jan 25, 2006 | 08:56 AM
firstimer's Avatar
firstimer
Put mine in a 'mylar' slip cover for 3-ring binders. Stationery (sp.) stores sell them.
