Bleeding Brake Lines
Old Feb 2, 2006 | 03:30 AM
BreauxBridgeKid's Avatar
BreauxBridgeKid
Default Bleeding Brake Lines
Anyone got a how to on bleeding brakes...or something to the fact.
Thanks,
Paul
Old Feb 2, 2006 | 06:20 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
I made a plate to replace the mc lid. I used 1/2 inch alum with 1/8 rubber gasket, then used a c-clamp to hold it on . Threaded it for 1/4 inch pipe. Put a ball valve on it and a qd on the othe end. Hook up your air hose with about 20 psi. Start at the farthest point from mc and work you way to the closest.
Old Feb 2, 2006 | 06:42 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Everything I've read from GM says purge from the caliper closest to the master cylinder and work to furthest away. Does not matter if you do the front or the rear system first. Purging air in this manner causes the air pockets to travel futher away from the MC.
Old Feb 2, 2006 | 10:50 AM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Default Paul
Thanks,
Paul
Dude, I am like 3 minutes from you and have a pressure bleeder...it works.
and...
Yes...I have a wrench to loosen the bleeder screw and know how to use it!
Hit me with a IM ....or I gave you my phone numbers already(will be on cell today).
Jim
To Bleeding Brake Lines
