St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I just finished modifying mine to fit the 4” side tubes. I will be blasting them and painting them with high temp paint in the next few days. The only down side is they only have 3" and 3.5 no 4" for the big block guys.
I have two in each pipe. I welded them together and added a cone shaped piece to the front to close off the center pipe. THe sound is awsome. I just tacked them into the pipe at the rear. They took a lot of hammering to get them in the pipe, I guess I didn't get them welded together as straight as I had thought. None the less they worked. Open side pipes was earpiercing.
