Air Compressor problems
Old Feb 4, 2006 | 07:29 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Air Compressor problems
My Porter Cable 60 gal compressor decided to stop today. Checked the power and I'm getting power to the motor. That rules out pressure switch. The GE 7hp motor has a reset, but pushing it does nothing. Motor spins very easy, so it's not froze up. What do you think it could be? Maybe the starting capacitor?
Old Feb 4, 2006 | 08:30 PM
big_G's Avatar
big_G
Check the brushes..(contacts).
Old Feb 4, 2006 | 08:36 PM
chevylit's Avatar
chevylit
The starting capacitor could very well be the problem,at least it
would bear checking out.
Old Feb 4, 2006 | 11:47 PM
JustForFun's Avatar
JustForFun
i have a friend whos compressor eats capacitors like fat lady does doughnuts.....
Old Feb 4, 2006 | 11:52 PM
ICEMAN59's Avatar
ICEMAN59
Disconnect the capcitor and discharge it (put a screwdriver across the terminals) put your multi-meter on ohms Rx10000 and put the leads across the capacitor. Reverse the leads and the capacitor should charge needle swings to the right and then discharge needle comes slowly back to the left. If it does this it is o.k. if not capacitor is bad.
Old Feb 5, 2006 | 08:48 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Good info, I will pull it out tomorrow night and give an update.
Old Feb 5, 2006 | 04:14 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Both sides of the capcitor, start at -3.15 and run up to 13. then 1. on multimeter. I only had a 20K setting.
There is also another capcitor looking part on top of the motor. What is it?
Old Feb 5, 2006 | 08:02 PM
ICEMAN59's Avatar
ICEMAN59
You could have two capacitors one for start one for run is there a relay? To check the capacitor put one lead on each side of the capacitor then switch them.
Old Feb 5, 2006 | 10:17 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
No relay, just two capacitors. I put the leads on each side and got the same results. Not following.
Old Feb 5, 2006 | 10:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
is there a pressure cutout relay that is malfunctioning?
Old Feb 5, 2006 | 11:19 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
That was my first thing to check. I'm getting 220V to the motor. It just want run. Thanks for the help. Buddy
Old Feb 6, 2006 | 08:51 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Alright figured it out. Brought the capacitor to the Motor repair shop and it checked out. They guy at the counter told me that you just about have to stand on thermo protection switch to get it to reset, so tonight I push on it pretty hard and "click" it reset. Got to love that honcho de mexico stuff.
Old Feb 6, 2006 | 09:17 PM
big_G's Avatar
big_G
Yea, mine is like that..nearly break your thumb re-setting it
To Air Compressor problems
