engine block ID
Old Feb 5, 2006 | 04:32 PM
olds120's Avatar
olds120
Default engine block ID
I just picked up a 73 vert project, can someone hlp me ID the engine?
The casting # is 6956618 and the pad stamp is K0131FB
Old Feb 5, 2006 | 04:38 PM
Supersportt396's Avatar
Supersportt396
Default Numbers
Try WWW.chevymania.com
Old Feb 5, 2006 | 04:46 PM
Mike Ward's Avatar
Mike Ward
The casting number is probably 3956698, check again.
If so, it's a '69 350 cu. in with turbohydramatric trans. 300hp 4 bbl from and A,F or X series car.
It was built by McKinnon Industries in St. Catheries, Ontario Canada on January 31.
Old Feb 6, 2006 | 12:23 PM
corvald's Avatar
corvald
Corvette used the castin#3956618 in the mid production on some cars in 1969, but they did not use FB on the pad. I have a 1969 327 engine
in my garage with cast.#3956618 and the stamp K0521FB.The 05 is for month, 21 for the day. If iam not wrong, i think FB is for Chevelle or Nova.
Old Feb 6, 2006 | 01:25 PM
olds120's Avatar
olds120
So its a 327 then? The guy I got it from thought it was a 327/365hp
Does that seem right for a 69?
Old Feb 6, 2006 | 02:24 PM
corvald's Avatar
corvald
I dont know what your engine is.The cast#3956618 was for both 302 ,327 and 350.
68-69 passenger, Chevelle, camaro, Nova 327
69 Camaro Z28 302, 4 bolt main
69 Corvette 350, 4 bolt main
69-74 pass, Chevelle, Camaro,Nova and Monte Carlo 350,
69-76 truck.
Old Feb 6, 2006 | 02:44 PM
corvald's Avatar
corvald
Hello again Olds 120,
I think i found it; your engine is a 1969 327 2 bolt.
K= engine plant St.Catherines, Ontario
01= January
31= day number 31
FB= 327 2 bolt w/powerglide fullsize 235 horse power.
Corvald.
Old Feb 6, 2006 | 03:42 PM
olds120's Avatar
olds120
01= January
31= day number 31
Corvald.
You are the man !!!!!!!
To engine block ID
