'80 Dash Replacment
Old Feb 5, 2006 | 08:21 PM
AlCherry's Avatar
AlCherry
Default '80 Dash Replacment
OK Guys and Gals. My wife and I are in full resto mode. All of the interior is done except for the dash. Any words of wisdom before we start? Anybody want to fess up to screw-ups that will keep us out of trouble?
Just a plug.... The Corvette America & Ecklers parts we've bought and installed have been top of the line. Everything has fit like a glove, and looks superb!!! By the way, we don't work for them.
Old Feb 5, 2006 | 10:11 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
There are two metal tabs that bolt to the underside of the dash that attach to the firewall. They are evenly spaced across the dash. They are designed to be bolted to the dash prior to installation. When installing the dash, they will simply clip into the firewall. To remove the old dash, you need to unbolt them from the dash. The passenger side is very easy. The drivers is directly above the tachometer with little clearance. Just be patient.
When installing the dash, pay very close attention to the ears that stick out off the top of the dash. They are very easy to crack and tear. You will have much better luck if someone helps you install the dash. It's very hard to move around by yourself inside the car.
Some people suggest dropping the steering column. I didn't, but I had bough a new steering wheel, so I removed the old and left it off before I put the dash on.
Good luck.
Old Feb 5, 2006 | 10:13 PM
The Ram's Avatar
The Ram
Good luck.
it is possible to remove and install the dash on your own, ask me how i know but it is better if you get a helper...and yes watch out for the ears!!!
Old Feb 6, 2006 | 06:36 AM
bickel's Avatar
bickel
lets see the pics of what you have done this far please!!!!!!!!
Old Feb 6, 2006 | 07:13 AM
1982CorvetteDude's Avatar
1982CorvetteDude
I'd like to know what stock they (ecklers and corvette america) are pulling your parts out of because I have yet to see anything from them fit like a glove
Old Feb 6, 2006 | 08:34 AM
mooneyd's Avatar
mooneyd
I dyed mine (in place) came out great. But I had no cracks, just went from blue to charcoal. If yours is in good condition ecept for color, you might want to try to dye it?
Old Feb 6, 2006 | 09:11 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
i'm in the same boat as you are. i'm trying to get help from friends to do this as i never done this before. so far glove box removed,duct wok under glove box,2 screws on sides by door posts,4 screws around guage cluster,speed and tach lens removed. thats as far as i got. mine is a 79e so i dont think there will be much differance. good luck
Old Feb 6, 2006 | 10:00 AM
The Ram's Avatar
The Ram
my reinstallation will be easy as im not reinstalling any duct work...so a few screws and im done
Old Feb 6, 2006 | 01:28 PM
Mrs. Al's Avatar
Mrs. Al
Cruising
Default Fit....
I put in the carpet by myself and it fits great! The door panels went in with no problem and the carpet on them matches the rest of the carpet. The only pieces that don't perfectly match are the tunnel cover pieces. They look like they were cut "against the grain" or taken from a selvage end. Bought new mounted seat covers and they fit right into my existing pans with no problem. Guess maybe we've just gotten lucky with our parts. Sorry to hear you've had problems........
Old Feb 6, 2006 | 01:30 PM
Mrs. Al's Avatar
Mrs. Al
Cruising
Default Pics...
I'll take some more next weekend and try to post them (got to figure out how)...
Old Feb 6, 2006 | 01:31 PM
Mrs. Al's Avatar
Mrs. Al
Cruising
Default No Duct Work??????
Why no duct work? I'm willing to make life easier for both of us so neither of us end up dead over a dash!
Old Feb 6, 2006 | 01:34 PM
The Ram's Avatar
The Ram
end up dead? whatcha mean?
Old Feb 6, 2006 | 03:40 PM
Ak. Mal's Avatar
Ak. Mal
Damn, if you two married folk are in the same thread making sure you won't rip each other's heads off, maybe you shouldn't be inside the car working together. It gets a little cramped in there.
Old Feb 6, 2006 | 04:00 PM
Mrs. Al's Avatar
Mrs. Al
Cruising
Yea, but it's fun being together in a cramped space working together. As for one of us ending up dead, he won't listen to me and I'm hard headed! Make sense now???? so, Ram, why no duct work?
Old Feb 6, 2006 | 04:54 PM
The Ram's Avatar
The Ram
im not going to have AC in it, nor heat because when this puppy is driven is on warm sunny days with the ttops off...plus i dont feel like spending the extra money to have the ac compressor and such replaced/serviced when i wont be even using them at all...
Old Feb 6, 2006 | 06:11 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Considering that the stock parts tend to not fit very well, how can we expect anything more from those poor Chinese communists?
Old Feb 7, 2006 | 07:34 PM
AlCherry's Avatar
AlCherry
We will survive. We were cramped in an RV for 2 weeks during Hurricane Rita. Though we did have a large living room. The front yard. Thank God for electricity.
The A/c & Heater suggestion is interesting.
Thanks for the info everyone, We will return the favors.
Old Feb 7, 2006 | 11:20 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Be careful with the small tabs that are at the top corners of each end of the dash... they have a crease to allow them to bend.. bend too much and the paint/die cracks...or worse...
Pre-fit the glove box door before you put the dash in...
Take your time... feels good once done but will take patience...
Old Feb 7, 2006 | 11:33 PM
1982CorvetteDude
My problem is the dash pad assembly / center guage bezel / tach -speedo lens. All were bought as new repro's and nothing wants to "line up". I haven't even tried to install the console parts yet
To '80 Dash Replacment
