WTF- How does this happen????
Old Feb 7, 2006 | 10:17 PM
olouieo's Avatar
olouieo
Default WTF- How does this happen????
I go look at the vette in the morning and this is what I find. I parked it inside the night before and the window was fine. I was the last person to leave and the first one to came in. I was so mad What the heck could had happened??? I did take the Window out about 2 months ago to replace some parts inside the door. Has this ever happened to someone else??? Is the 68 glass a one year only?? Does anyone have one for sale??
Old Feb 7, 2006 | 10:27 PM
DMONSVETTE's Avatar
DMONSVETTE
Heat?
Old Feb 7, 2006 | 10:29 PM
shafrs3's Avatar
shafrs3
Wow, looks like someone took a spring loaded punch and popped your window. The glass curvature is the same; the markings on the glass between the years may be different.
Old Feb 7, 2006 | 10:30 PM
Glasman66's Avatar
Glasman66
I'm sorry to see you problem. I've been installing auto glass for sometime and have owned my own glass shop for the last 13 years.
My first suspect would be the work that was done two months prior. The door glass is tempered, what this means is that is heated to temperatures near melting point and then cooled very quickly. The glass behave totally different than regular or laminated glass like the windsheild.
If it is hit hard even with a rock or a hammer it may not break, but it is bruised. This can lead later on to it imploding without warning.
The otherthing is it could have had an edge hit, this will make the piece break very easily.
When you were working in the door was the glass hit or were the holes in the glass lined up right (I beleive there are holes where hte regulator bolts up to spanner nuts, not sue I'm a C4 guy)?
This could have set it up for failure.
Old Feb 7, 2006 | 10:36 PM
big_G's Avatar
big_G
Maybe you over-tightened the glass mounting parts when you had the glass out?....Maybe a temperature change aggrivated the mounting....C-3 'vert glass is different than coupe glass, but 68 has extra holes in glass that 69-75 don't. They can be found in Corvette salvage yards, G/L
Old Feb 7, 2006 | 10:40 PM
olouieo's Avatar
olouieo
I think they lined up but it was my first time doing it.
I think you guys are right. I can think of anything else. I am just curious why it took so long to break. Oh well, I guess I need to just find another.
Old Feb 8, 2006 | 12:02 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it happened to my wife in our volvo station wagon...she went to role the window down and it exploded....its probably from years of stress and it finally gave way...its a good thing it didn't happen when you had a passenger in the car
Old Feb 8, 2006 | 12:00 PM
Bangkok Dean's Avatar
Bangkok Dean
Well it was dirty anyway. Good luck finding a new one
Old Feb 8, 2006 | 12:06 PM
Frankenvette's Avatar
Frankenvette
At least you were not driving down the highway at a high rate of speed when this happened... could have been real ugly
Old Feb 8, 2006 | 01:07 PM
SharkAttack's Avatar
SharkAttack
A similar thing happened to my 71 coupe (long gone but missed). It was in my mother's garage and under a cover for a week. I pull the cover off to drive it home, only to notice the passernger window is spidered just like yours. Still believe someone accidentally hit it with something, but the car cover showed no signs. No work had recently been performed on the door or window. Twighlight Zone...
Old Feb 8, 2006 | 01:33 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I worked with a guy who had that happen to his Honda.
It was sitting in the parking lot, it was fine when he got to work, but at lunch time, after a thunderstorm, it was shattered.
We wonderend if it was the temperature change or the thunder, or maybe both...
So it does happen.
Old Feb 8, 2006 | 02:01 PM
rihwoods's Avatar
rihwoods
Here is one for you guys...was aboard a 90,000 ton tanker going thru Panama canal..after we cleared locks,it started to rain..real hot day...the centerline wheelhouse window shattered...we had to bust it out so helmsman could see to steer...
Excuse fuzzy pics...digitals of old prints...we put plexiglass in later...
Old Feb 8, 2006 | 02:17 PM
1970 Dave's Avatar
1970 Dave
[QUOTE=427V8]I worked with a guy who had that happen to his Honda.
The Honda was "asking for it"
SEMPER FI--1970 Dave
Old Feb 8, 2006 | 02:22 PM
olouieo's Avatar
olouieo
So it does happen, I was going crazy I am sure glad it didn't happen while I was driving. Now I have to find a window.
Old Feb 8, 2006 | 02:31 PM
another-user's Avatar
another-user
i cracked the window on my sunbird when i washed it. we figured it was probably cooking inside the car, and when the cold water from the hose touched the windshield it cracked it.
i learned an important lesson that day. if its hot out and you want to wash your car, roll down the windows for 10 mins or so before hand.
Old Feb 8, 2006 | 07:21 PM
Glasman66's Avatar
Glasman66
Windshields are not tempered that is why temperture spreads the crack. It is laminated the glass is hot and when you put water on it the outside sheet contract while the inside sheet stays the same or does not contract fast enough to keep up, thus the crack.
Tempered is a totally different animal. The glass is cooled so quickly that the inside glass is trapped by the outside that cooled so quickly. That is why it explodes when it breaks, it releases all the tension.
Old Feb 8, 2006 | 07:24 PM
Glasman66's Avatar
Glasman66
I just checked my suppier and they do not have the galss, I will check some of the others and get back to you.
To WTF- How does this happen????
Old Feb 8, 2006 | 08:45 PM
Scottys78's Avatar
Scottys78
that suxs
Old Feb 8, 2006 | 10:32 PM
kevinator80's Avatar
kevinator80
You weren't riding my kids around were you? I tell them all the time "you don't have to slam car doors!!"
Old Feb 9, 2006 | 12:30 AM
c3 in hawaii's Avatar
c3 in hawaii
I guess my kids aren't the only ones to do this,..
