Snow blower trouble
Old Feb 14, 2006 | 07:36 PM
Scottys78's Avatar
Scottys78
Default Snow blower trouble
For some reason the blades that spin and shoot the snow out are getting clogged up and the thrower is not working……its not that I’m pushing the limits on how much snow it can take…..I bought it only 3 years ago and have changed the oil and everything regularly……what do some of you think
Old Feb 14, 2006 | 07:38 PM
kidneyboy's Avatar
kidneyboy
Move to California?
Old Feb 14, 2006 | 07:41 PM
jdmick's Avatar
jdmick
Assuming you have full power try spraying some cooking oil on the blades.
Old Feb 14, 2006 | 07:45 PM
PRNDL's Avatar
PRNDL
the snow is wet!!! It sux... I have never tried cooking oil, but you just know that there should be something slick that you can spray on the blades that will work.
Old Feb 14, 2006 | 09:02 PM
Higs's Avatar
Higs
You most certainly have a flat lobe on your cam.
Old Feb 14, 2006 | 09:11 PM
Gordonm's Avatar
Gordonm
I had my chute clog a few times this weekend. The bottom layer of snao was very wey and heavy. If you kept it going it would not clog. As soon as I slowed down a little it would clog. Still beats shoveling anytime.
Old Feb 14, 2006 | 09:25 PM
gator79's Avatar
gator79
comp cam XE
Old Feb 14, 2006 | 09:53 PM
michael c. volpe's Avatar
michael c. volpe
bounce it up and down a few times to shake off the stuck snow.
thats probably all it is.
Old Feb 14, 2006 | 10:08 PM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
Check tightness of belt as a possibilty as well.
Old Feb 15, 2006 | 07:28 AM
Sleper's Avatar
Sleper
Have you broken a shear pin. If the blade spins (machine off) freely there is a soft bolt (Shear) that holds the blades to the shaft. You may have picked up a rock and broken the shear bolt?
Old Feb 15, 2006 | 07:45 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Have your belt checked......you might need a new one....as they age they start to slip and you lose full power.
Old Feb 15, 2006 | 08:45 AM
Paul L's Avatar
Paul L
If you have at least 8hp then it has to be the belt. A 5hp unit is marginal at best and will not have enough oomph for heavy, wet snow. Use PAM spray cooking oil on the blades.
Old Feb 15, 2006 | 03:57 PM
Scottys78's Avatar
Scottys78
I took out the garden hose and hosed all the snow off and started to use the machine again and it worked fine for a few minutes and then just clogged up again. I was going kind of slow to makes sure I didn’t overload it.
Old Feb 15, 2006 | 04:12 PM
NHvette's Avatar
NHvette
Have you lubed the impeller and/or the chute ?
Try cleaning it out again and coat the clogged areas with WD40,
or PAM, or even ski wax.
Old Feb 15, 2006 | 04:18 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
How big is it? How may HP? One or two stage blower?
I've got an 8 (7.75HP) Craftsman with 6 forward gears and 2 reverse gears. It'll blow snow 20 feet, but it will clog up and slow down in wet snow. Pam works well.
If you've got a little "put put" snowblower, it'll plug up in an instant with heavy wet snow. Chuck
Old Feb 15, 2006 | 05:32 PM
alanbl's Avatar
alanbl
The main problem is that you need something a little more substantial to do the job.
Old Feb 15, 2006 | 05:34 PM
GTR1999's Avatar
GTR1999
All good ideas- the ski wax is good as is PAM.
Check the shear pins,side bushings, belt. I've had to rebuild a couple of these and they're not too bad- better then working on a vette!!!
The transmission is driven by belt and a rubber disc that wear down so check that during a pre-season PM. I had the sprocket that drives the "posi" wear down and jump a tooth. They call that the jack shaft is I recall even though it's a sprocket.
Also I ran a 4hp 1966 Aries for years through everything. The agur and gear box were HD not the cheaper type used today. That little 4hp, once tuned up with points and timing fired up every 2nd pull.
I think the best solution was a warm climate change though~!
To Snow blower trouble
Old Feb 15, 2006 | 08:20 PM
BIGsteve's Avatar
BIGsteve
If it is a 2 stage blower (augers in front, impeller in the base of the chute), check if the impeller is turning. It throws the snow up the chute. Without the impeller working properly, the snow stays in the auger area. If all is working well, they can still clog in the chute from wet snow, not in the lower (auger) area. If it is a 1 stage blower, the whole thing is combined into one, not so efficient process. The 1 stage blowers have a very tough time with heavy wet snow, to the point of what yours is doing.
I have a 25 year old Ariens 8 HP/2 stage blower that has always had a little trouble with heavy wet snow when it's over 6-8 inches deep.
Old Feb 15, 2006 | 08:38 PM
Scottys78's Avatar
Scottys78
I have an 8HP Snapper......I think its two stage....there are two type of blades that spin. I have 5 or 6 foward gears and 1 reverse
Old Feb 15, 2006 | 10:36 PM
jlaw68's Avatar
jlaw68
how about this
