help with engine numbers
Feb 14, 2006 | 11:34 PM
here are some numbers off of my 454 in my 71. I know the block is not original but it looks like the heads and intake may be.
head #'s GM12T
H27-70 (date code?)
3993820
the numbers are the same on both heads
intake #'s GMT
H26-70 (date code?)
3955287
block #'s GMT7
the block has HI PERF stamped on the back of the block passenger side
OK what do I have, are theese heads any good?
Feb 15, 2006 | 09:28 AM
Hope This Helps..........
Per "Chevymania".........
#3993820 - 402/454 71 2.06/1.77 113cc Oval port
#3955287 - 402/454 70-71 Q-jet Oval port LS-3/LS-5
Ya' got anymore block numbers, besides the GMT7???
Feb 15, 2006 | 10:19 AM
I'd say the 820s are the best oval/open port heads
edit: and with the 2.19 1.88 valves make more horsepower than rectangle ports
Feb 15, 2006 | 01:45 PM
more block numbers
found a few more block numbers.
E-17-71
last four of the casting are 3512 canot make out the first numbers.
it also has a "P" stamped near the casting number
Feb 15, 2006 | 02:00 PM
Heads are correct for your year 3993820 454ci, 365hp
Block is correct also for your year 3963512 454ci 365hp,425hp.
Feb 15, 2006 | 02:20 PM
Again, from Chevymania.........
#3963512 427/454 69-71 335-450HP 2 & 4-Bolt COPO
Feb 15, 2006 | 10:26 PM
now, if only the number on the front block pad matched the one on my vin tag that would be even better.
the block must have been changed early in its life. I know for sure it has had that engine for the past 25 years
