hurst install question
Old Feb 17, 2006 | 08:14 AM
7Deuce's Avatar
7Deuce
Default hurst install question
Can you install a hurst shifter through the console from above? I would be installing the shifter as well as new linkage on my 72 sb. I've been told by a mechanic that they would have to get at it from underneath and possibly drop the tranny/driveshaft to get at it. Does this sound right?
Old Feb 17, 2006 | 08:41 AM
b71vette's Avatar
b71vette
Default From top and below
Should not need to drop tranny or remove drive-shaft, but it is tight.
Old Feb 17, 2006 | 08:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Impossible to install everything from above. I could install only the handle through the console. The linkage definetly from below.
Old Feb 17, 2006 | 12:38 PM
ajstr1265's Avatar
ajstr1265
Installed one in my 76. Done from the bottom. Very very tight. the linkage must be done from the bottom. I took the old shifter out through the top. The hardest part is the linkage
Old Feb 18, 2006 | 01:16 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I just did this on my 76 in November. All from the bottom. It helped that the exhaust was out at the time.
To hurst install question
