Hydro boost question
Old Feb 20, 2006 | 01:12 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Default Hydro boost question
What size and type fitting do I need for the pressure line on the power assist valve? I need to order the fittings to plumb my HB. I have the size for the adapters on the HB, but am unable to locate the size and type on the power assist valve. I will be going with 6AN fittings.
Old Feb 20, 2006 | 02:08 PM
pmazza's Avatar
pmazza
If I remember right, both are inverted flare..pressure side is 7/16-24 thread and return is 5/8-18. Aeroquip makes a 90 degree hose end with the 5/8 IF fitting, I had to use a AN -4 to 7/16 IF adapter out of the valve and then I stepped the -4 up to a -6 on the flex line that moves with the valve.
I switched to the Saginaw 12.7:1 box a year ago, but I still have the old valve and hoses that I can check tonight to verify if you need.
Phil
Old Feb 20, 2006 | 02:48 PM
Twin_Turbo's Avatar
Twin_Turbo
if I remember correctly it was an UNF thread w/ o ring seal...very weird.
Old Feb 20, 2006 | 03:22 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I jsut used my stock lines and got them lenghtened.
Old Feb 20, 2006 | 07:58 PM
pmazza's Avatar
pmazza
Fitting sizes I had above are confirmed, both are inverted flare. (fine thread as Twin Turbo noted).
Phil
Old Feb 20, 2006 | 08:08 PM
chevymans 77
Thanks for the help. Gotta find them and order them now.
To Hydro boost question
