Block Numbers
Old Feb 20, 2006 | 03:50 PM
MGBONE's Avatar
MGBONE
1st Gear
Default Block Numbers
Hey, this is my first corvette, & I am trying to decode these 2 numbers I found on the front of my block. Aren't they supposed to tell you the year, hp, etc.... If anyone can help I could sure use it!
Thanks,
Derick
#'s 06F363410 & V1215TYZ
Old Feb 20, 2006 | 04:48 PM
RHD '68 L89's Avatar
RHD '68 L89
Had a quick check in the Corvette Black Book. The TYZ code on the end of the second number gives the HP and application. Unfortunately the TYZ code appears to not be a C3 Corvette code.The longer number should be the VIN derivative and should match the VIN tag inside the drivers side windscreen. I would say it is probably not the original motor. Someone may be able to decode the TYZ for you.
Old Feb 20, 2006 | 05:22 PM
jotto's Avatar
jotto
had a quick look on the net.....engine Suffix Code TYZ indicates its a 1975 LS9 350 cubic inch engine rated at 165HP
corvald's Avatar
corvald
Thanks,
Derick
V= plant: Flint, 12= mont (Desember) 15= day TYZ:Appl. 350 conv cab, 165 hp, 4 bbls, body: C10 to2500
Old Feb 20, 2006 | 06:07 PM
stingr69's Avatar
stingr69
The "T" generaly gives it away as a Truck application.
-Mark.
To Block Numbers
