Looking at a 76 ????
Old Mar 1, 2006 | 01:54 AM
Jack60's Avatar
Jack60
St. Jude Donor '08
Default Looking at a 76 ????
My buddy is looking at a 76 coop this weekend, is there anything we should make sure we checkout. Any place that rust is a problem spot on a 76.
I have a 60, so I don't know these new models.
Thanks for any help.
Old Mar 1, 2006 | 08:29 AM
Vette Gator's Avatar
Vette Gator
There have been many threads on this subject, including a very nicely written summary of places to look that was posted just the other day. A quick search should turn them up. There will be good descriptions of birdcage areas and places on the frame to watch. These are common to all C3's.
On 76's specifically, look closely at the floor pans. I'm told that they were galvanized from 78 onward and that this helped a lot (unless you have a 76!). It's not impossible to repair or replace these, but it will add time and expense.
Old Mar 1, 2006 | 11:06 AM
SpcCox's Avatar
SpcCox
The bottom of the radiator support is almost always rusted out, sometimes to nothing.....Something to keep in mind of the price for the car when a new one costs around 300 bucks, unless you are a good welder. Also if you can see the corners of the windshield on the birdcage...thats a usual as well. Some of the other places for rust are ones that you can't see....You might be on your own there.
However you can usually gauge what the hidden spots might look like according to the rest of the car. If the car looks pretty good all around you might not have anything to worry about....but if it's got some rough areas that you can see, plan for finding some in the future...just my .02 cents
Old Mar 1, 2006 | 12:43 PM
vetteboy1976kr's Avatar
vetteboy1976kr
In addition to what those before me said I would check out the body mounts. Pull the kick panels off in near your feet and check the birdcage at the #2 mount on each side. If there is rust there, chances are it is up near the winsheild. Also the #4 mount in the rear wheel well. Not quite as expensive and time cosuming to fix, but worth looking at.
Old Mar 1, 2006 | 12:48 PM
72LS1Vette's Avatar
72LS1Vette
The floors on my 79 are rusty but still OK structurally, so I can't be sure if they were galvanized or not. There are reproduction floorpans available but I think they are over $300.00 each.
On the later model C3s you have to have a good idea of what a pristine car is worth and be able to estimate how much $ it would take to make the car you are looking at pristine. If the numbers are too far off it might be better to look at another car.
If you have different motivations - learning experience, family project, want to t-off significant other, etc., realize that pretty much anything that is wrong with a Vette can be fixed or replaced. You just need time and money.
Rick B.
To Looking at a 76 ????
