Some Eletronic Problem...
Old Mar 2, 2006 | 05:12 PM
Antonst's Avatar
Antonst
Default Some Eletronic Problem...
Ok I got 81, can anybody help me, The fuse for the power locks, the clock, the lighter, Courtesy, Anti-Theft alarm, Glove Box, Dome, Power Antenna, Horn Relay..
The fuse always explode when i put it in,i dont know where to look.
Any idea for me where to start search.
and can anybody tell me where the horn is in the car
Old Mar 2, 2006 | 05:27 PM
kona's Avatar
kona
You most definitely have a short. Have you installed anything lately or repaired anything in which you might have pinched a wire or drilled into a wire?
Kona
Old Mar 2, 2006 | 06:37 PM
crazywelder's Avatar
crazywelder
In the repair area at the end of the line, we would just put a bigger fuse in and look for smoke! No don't do it. Pull the lighter **** and try the fuse again or check the dome light switches for an internal short. Also check the wiring harness that goes through the door jams for cracked or broken wires.
Old Mar 2, 2006 | 08:29 PM
jdp6000's Avatar
jdp6000
Process of ellimination. Have someone push the stop in the door for the interior lights. No key in the ignition. Put the fuse in. Does it blow? If not release the door stop...does it blow? If not try the lights....etc etc. Until you find what blows.
Jim
Old Mar 2, 2006 | 08:41 PM
Higs's Avatar
Higs
Horns right behind the nose, can see one from top, and one from laying on the ground looking up.
Take all the light bulbs out, horn relay etc... and see what happens. Then start putting them back in. Don't forget the passenger side vanity light if you have one. That's where my short was, behind the windshield trim.
To Some Eletronic Problem...
