New engine pictures
Old Mar 2, 2006 | 06:00 PM
Gordonm's Avatar
Gordonm
Default New engine pictures
Everyone always wants to see new engine pictures. Does not look any different than my old one but should produce more power. Trial fit the headers today. There was some slag left in the holes. Much easier to do it on the stand than in the car. It is getting there, dingy valve covers and all.
Old Mar 2, 2006 | 06:16 PM
Emeightch's Avatar
Emeightch
Default Sweet...
Whats the specs?
Old Mar 2, 2006 | 07:24 PM
Tonys96's Avatar
Tonys96
Lookin' good.
Old Mar 2, 2006 | 08:20 PM
markdtn's Avatar
markdtn
Nice looking
Old Mar 2, 2006 | 08:23 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Looking good. Just in time for spring.
Old Mar 2, 2006 | 08:24 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I see hockey sticks
Old Mar 2, 2006 | 08:32 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Looks cool/ I like the intake bolts...where did you get them?
JIM
Old Mar 2, 2006 | 08:52 PM
redc3's Avatar
redc3
Originally Posted by Emeightch
Whats the specs?
Old Mar 2, 2006 | 09:09 PM
Gordonm's Avatar
Gordonm
JIM
One of the Industrial distributers that I work with is a bolt distributer. They are Stainless Steel button heads. I was wondering if anyone was going to pick up on them. They are not a very common bolt.
The engine specs are in my signature.
Old Mar 2, 2006 | 09:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
vroom vroom......looks good, what are those tapped holes on the side of the Demon for? are those mounting locations for vacuum secondaries? I have the vacuum secondaries so i'm guessing thats why i have never noticed those before
Old Mar 2, 2006 | 09:13 PM
76project's Avatar
76project
Nice and clean, i like it.
Old Mar 2, 2006 | 09:34 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Gordon kicks ***!
Old Mar 2, 2006 | 09:37 PM
big_G's Avatar
big_G
Can you get enough torque on them? Are they allen heads?
Old Mar 2, 2006 | 09:39 PM
Perfomer's Avatar
Perfomer
The stainless bolts are good but I have heard that they will gauld when they are used in aluminium . Something about the threads being very sharp.
Old Mar 2, 2006 | 09:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Lookin
Old Mar 2, 2006 | 10:08 PM
rosslato's Avatar
rosslato
looks great, especially like the color u painted the block and pan, is that por-15 red? mine will be that color within a month.
Old Mar 2, 2006 | 10:36 PM
Maine Vette's Avatar
Maine Vette
That motor looks awesome!
I believe your referring to the phenomenon called "galvanic corrosion" which has been discussed at length here on the forum.
Essentially, all metals have different electrical potentials, some act as anodes (active metals) while others act as cathodes (passive metals). If two metals with reasonably dissimilar potentials are placed in contact with one another in the presence of an electrolyte (water, especially salt water), electrons will transfer from the active metal into the passive metal. This transfer of electrons results in the deterioration of the active material.
In the case of Stainless Steel and Aluminum, they are fairly dissimilar metals with aluminum being the sacrifical metal. However, what's missing in the case of a car engine is the constant presence of moisture. Although the engine may get wet occassionally, the heat from the engine drys the water before any substantial deterioration occurs. The two metals would have to remain wetted for quite a long time (probably years) before any substantial deterioration occured.
Just My $0.02, but I probably just re-opened a can of worms...
To New engine pictures
Old Mar 2, 2006 | 10:43 PM
Monty's Avatar
Monty
Antiseize or a moly based thread lube (I use the ARP brand)will do the trick. We use stainless steel fasteners almost exclusively on offshore powerboats where hot, humid, salt water conditions are common and it will go a long way in preventing the stainless fastener from stripping or damaging the aluminum receiver component. Thread lube should always be used with stainless fasteners.
Old Mar 2, 2006 | 10:48 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Looking good. More power, new stuff...cool. I hope to have mine running on Sunday.
Old Mar 2, 2006 | 10:53 PM
Maine Vette
, good point. Although significant corrosion is unlikely occur some minor deterioration will occur. The result is a powdery residue that can bind up the bolt threads. Thread lube will go a long way in preventing and mitigating this issue.
