bye c3
Old Mar 5, 2006 | 01:46 AM
randy814u's Avatar
randy814u
Default bye c3
Old Mar 5, 2006 | 05:58 AM
91DRM's Avatar
91DRM
From: Isle of View "Mofo skated me, that was my up!"
Old Mar 5, 2006 | 07:05 AM
Batsy74's Avatar
Batsy74
Old Mar 5, 2006 | 09:48 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Originally Posted by randy814u
I have never posted much, just hung around to get info. I carbed my c4. and got some info on carbs and cams here. You have been a good group. I sold my 78, and put a 98 in the driveway. I will always miss her. I sold her to the guy a across the street, so maybe I can see how she is doing. Thanks for the help you never knew you gave me. Randy
Randy... You can always buy it back! By the way... like all of your toys. Just showed my wife and I received the dreaded "whatever".
Take care and I agree with you on the value of this forum... this place is awsome for someone in his first years as a C3 owner.
Ed
Old Mar 5, 2006 | 11:41 AM
71redskin's Avatar
71redskin
i showed your pic to my wife and she says, yeah, maybe if we hit the lottery...
Old Mar 5, 2006 | 12:07 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im sorry you sold your c3 to get a c5.
Old Mar 5, 2006 | 12:12 PM
StickShiftCorvette's Avatar
StickShiftCorvette
At least in your trade you got close to classic C3 performance levels!!
Old Mar 5, 2006 | 12:20 PM
Star79's Avatar
Star79
Hey, show us a picture of your truck.
Old Mar 5, 2006 | 12:56 PM
Star79's Avatar
Star79
Haha, that's exactly what I hope my house will look like in about 5 years (C3, C4, C5, C/K) only the colors will be different and I only need a 20ft boat!
Old Mar 5, 2006 | 01:02 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I know you're not talking about the C5 and I don't think the silverado is faster than the C3!
Old Mar 5, 2006 | 01:50 PM
StickShiftCorvette
I AM talking about the C5.
I've driven a C6 and it is finally comparable with my '69 C3. I have G-tech tested C5's and they are not up to the best of the '68 and '69 C3s.
Stock C5's aren't even close to a modded non smog SB, or the hot '69 factory options: 427/435's, L-88's, and ZL-1's. Since I wasn't old enough to drive when they built them, I don't mind if anyone builds their own.
A lightly modded C5 is 14% less powerful than my 355 SB and about 20% less powerful than a L-88 on a peak power basis. Of course they are not as thirsty.
Old Mar 5, 2006 | 01:56 PM
RPOZ4Z's Avatar
RPOZ4Z
just curious.
what's your 355 putting down to the rear wheels?
and the 68 and 69's would HAVE to be running mid to high 12's in the 1/4 mile to beat a well driven C5.
and I'm talking stock to stock, not modified.
not to mention the beating that they would get on a road course.
Old Mar 5, 2006 | 04:48 PM
StickShiftCorvette
just curious.
True stock to stock on a road course C5s would trounce a C3. On equal tires, not so - L88s, ZL-1s and 427-435's running 17" rubber similar to mine (Goodyear Eagle F1s) would do well on a fast enough track.
The G-tech shows my '69 at 320 RWHP. The following will provide a reference I have tested many cars/bikes:
Car - Engine if Options-----------------------G-Tech RWHP
93 Corvette Stock 300 NET HP-------------------193
63 Corvette 327-300 Gross HP stock-------------165
69 Corvette 350-300 Gross HP stock-------------170
69 Corvette L88------------------------------------345
01 Corvette K&N 350 NET HP--------------------274
04 Viper SRT-10 stock 500 NET HP--------------414
01 Yamaha R-6 stock 120 NET Crank HP---------94
02 Trail Blazer (3) 270 NET HP stock------------174,178,180
03 Silverado 6L 300 Net HP stock----------------203
My small block is pretty wild:
355 Corvette Engine Specs/Info
4.030 Bore X 3.48 Stroke
Main Brgs S.P. 360 7001 Tri Metal Std Size
Main Torque - Long 70 Ft-Lb, Short 65 Ft-Lb w/105 Grease
Rod Brgs FM #7095CH (Tri Metal (Std Size))
Crank Balanced to 1698 g Bob Wt.
(Ring,Piston,Locks 630;Small End Rod186;Rod Big End x 2 798;
Brgs x 2 84)
Rods - Lunati Street Race 6” #LHD1 Full Floating Bushing
Rod Torque 38 Ft-Lb w/Lunati Lube - .005-.0055 Stretch
Pistons Sportsman Racing Products (Division of JE Pistons) #138085 Forged Hi Silicone;
Clearance @ Pin Bottom .003” Thrust side; Flat Top; 5cc equal valve notches; NO Lor R; .927 x 2.5” Pin; 1.260” C.H.
Compression Ratio - 10.67: CR
Oil Pump - Chevy Melling HV55
Timing Set - S.P. #220-3100 .25” Double Roller Timing Set
Rings - SP #R9771 +.035 - 1/16,1/16, 3/16 - Top Gap .018-.020; 2nd .014-.016
Std Temp Oil Ring, Moly Ductal Top Ring
Heads - Brodix -8 Pro; Originally Milled .027” for 65cc Volume
Lunati Springs Setup @1.875=130#, @ .500 Lift 310#
Flow @ .500 Lift @ 28” Depression (Vac) 240 CFM Intake, 160 CFM Ex.
Cam- Flat Solid Tappet Comp Cams 294S Magnum
Adv Duro Duro@.050 Lobe Lift
Int+Ext 294 248 .350 110 Lobe Centers
Lunati Roller Rockers - Intake 1.6:1 .560 Lift, Ex 1.5:1 .525 Lift
Installed 2 107 Deg CL @.050; Manley Push Rods Stock Length #25709 (7.800”)
.022” Hot Lash - Set .005 Tighter Cold w/Aluminum Heads
Valve to Piston Min Clearance - .173 Intake; .192 Exhaust
MSD Billet Distributor
Old Mar 5, 2006 | 05:11 PM
RPOZ4Z's Avatar
RPOZ4Z
I'm basically stock with the exception of an aftermarket air cleaner.
I had the car on a chassis dyno and I'm putting 324Hp and 333Tq to the rear wheels.
I don't think the Gtech is that accurate. a stock LS1 corvette should be between 295 to 315 at the rear wheels depending on transmission and rear gear ratio.
and on a road course the C3's will need a hell of a lot more than 17" wheels to even keep up with a stock C5!
there have been a lot of advances made in suspension technology in the last 40 years, and the over 40 year old chassis technology of the C3 cannot even begin to compete with a stock C5 without some major help.
Old Mar 5, 2006 | 06:25 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
First you replaced a good FI system with a carb (in a rolling door wedge), then you sold a C3 to get a C5?
Old Mar 5, 2006 | 10:54 PM
Scottys78's Avatar
Scottys78
looks like my '78 with the '80 back bumper!
Old Mar 5, 2006 | 10:57 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Is your house pink?
To bye c3
Old Mar 5, 2006 | 11:17 PM
lucky76's Avatar
lucky76
Just a plain jane 96 silverado 4x4. Yes it does pull the boat. Plus the girlfriend has a 02 beetle. I need a bigger driveway, or have to let something go.
If your Girlfriend has a Beetle, who drives all the Vettes and the truck?
Old Mar 5, 2006 | 11:35 PM
Star79's Avatar
Star79
If I find a woman who will let me have three Vettes a p/u and a boat I'd let her paint gay cowboys all over my house.
Old Mar 6, 2006 | 01:36 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
First of all it was not a perfectly good fi, and with the engine mods and carb, and a newer 6speed, it will keep up with the c5 from a start and on the road. If you look in the pic you will see I still had the c3 after I got the c5. I did not sell the c3 to get the c5, I sold the c3 because I hardly drove it before, and with the c5, it would have just set out side and rusted away. Now from your post I can see you think that is a good idea, I don't. It just became the first vette for someone, and will be drove and taken care of.
Also, I posted this thread to say thanks for all the c3'ers that have helped me and never knew it. I did not start this post so you could take a cheap shot, and raise your post count. Randy
Overreact much? Yeesh. Personally, I'd rather drive a hot-rodded C3 than any C4 or C5 (except maybe a ZR-1). I just like the look much, much better.
