map pocket
Old Mar 8, 2006 | 02:44 PM
cab's Avatar
cab
Default map pocket
what all is involved in replacing the map pocket mine is sagging pretty good. will i have to remove the entire dash? that might be a little much for me to tackle.
Old Mar 8, 2006 | 03:17 PM
chevylit's Avatar
chevylit
If I remember right just remove the visible screws that You can see
on the front of the pad and it will come right out .
Old Mar 8, 2006 | 03:21 PM
James1970's Avatar
James1970
Easy fix: Remove passenger dash panel. On the back of the panel, you will find that the pocket is attached by four phillips head screws w/springs.
While you've got the dash panel out, it's a good time to replace the vent ball.
Good Luck!
Old Mar 8, 2006 | 04:17 PM
cab's Avatar
cab
thanks guys here goes nothing.
Old Mar 8, 2006 | 04:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
This is going to sound mean, but if you're afraid of the map pocket, maybe owning a vintage Corvette is not for you. They require quite a bit of tinkering, which can lead to big $ at the repair shop.
Old Mar 8, 2006 | 07:00 PM
76project's Avatar
76project
Go for it, you learn by taking it apart. There is plenty of help here if you get stuck.
Old Mar 8, 2006 | 07:26 PM
carl a's Avatar
carl a
all thats holding it in is the screws in the top which go into dash pad(i believe 4 screws) and the ones coming in from the guages,then 2 when you open the passenger door, then it wil probably fall out
Old Mar 9, 2006 | 01:38 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old Mar 9, 2006 | 09:40 AM
cab's Avatar
cab
gotter done, took maybe 20 min. had to cut and rebend the springs. just didnt know what all was involved batman. thats why i ask the pros. thanks guys.
Old Mar 9, 2006 | 12:03 PM
Milest's Avatar
Milest
What a poor reply. Guy was asking a question and you dump on him.
You just made my ignore list.
Cab - glad you were able to repair it, ask any questions you want here.
Old Mar 9, 2006 | 12:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Cab, glad you got it all worked out. My point was that some people aren't mechanically inclined (hopefully you're not one of them!), and these cars tend to need quite a bit of tinkering. The best advice I can give is to get the service and assembly manuals, and dive in on whatever needs to be done!
Milest, you completely misinterpreted me - I just was concerned that someone apparently new to working on these cars might not be aware of the work that's often involved in keeping them running and in good shape. I'm sorry you jump to conclusions so quickly.
Old Mar 9, 2006 | 01:06 PM
cab's Avatar
cab
batman for your info i am not a mech. man. i do rely on you guys. last month i was going to have a guy replace my rear carpet and doors. after he made no progress i went and got it and me and a 6 pack got it done with the forums help. the only thing i have left is window pillar rot i need replaced and i know i cant do that. been looking for someone in the general area but no luck yet. you guys are the best help any manual could have and i APPRECIATE your time.
thanks andy
Old Mar 9, 2006 | 03:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
cab, sounds like you're doing fine! Welcome to the fever...before long you'll be doing a frame-off.
Old Mar 9, 2006 | 06:55 PM
sly vette's Avatar
sly vette
Come on Cab,YAHOO
Later,
Sly
Old Mar 9, 2006 | 08:56 PM
cab's Avatar
cab
yea sly i could get it to that point but you better have plenty of retirement or vacation time to come to the warm state and put it back together. can u imagine how many threads i would have on that one.
Old Mar 10, 2006 | 12:03 AM
mkflanagan's Avatar
mkflanagan
Old Mar 10, 2006 | 12:42 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ok, ok...I came across harsher than I should have, and I have admitted to that. I was concerned that someone might be on the road to getting in over their head - the constant tinkering involved with owning a 25+ year old car can be overwhelming to some people. Sorry for offending anyone.
To map pocket
Old Mar 10, 2006 | 03:55 AM
sly vette's Avatar
sly vette
I retire in two years... It's a date,I mean APPOINTMEMT...
Old Mar 13, 2006 | 09:43 PM
Milest's Avatar
Milest
Default Copy of PM sent to Batman
Batman,
I unfortunately did "jump to conclusions" a few days ago. I had just read too many smart remarks to guys trying to fix stuff and I was unfair to read your responce as that. After some reading, I have found your posts to be both informative and an asset to this site.
I hope you will accept my explanation, and not hold it against me.
Good luck to you.
Milest
Old Mar 14, 2006 | 03:02 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Milest...no worries. I didn't intend for my original post to sound as harsh as it did. I try to make myself useful when I can, there is far too much that I still don't know about these cars.
