Front crossmember pan/a-frame brackets
Thanks! John
but they are only pocket welded down the center.
To make them really work, you weld a bead down each side
and add gussets at the rear. Often the pan/bracket can rust
near the two front bolts and weaken the crossmember.
If too weak, some have been known to tear away from the crossmember.
Rather than repairing the dinged bottom of my crossmember,
I added a reinforced plate for jacking.
Thanks. John
There are some pressed pieces that comprise the top-rear
portion of the bracket. Perhaps these can be salvaged.
Here's a series of pics showing the gusset install on the side of these pieces:
http://nhvette.homeunix.com/ftp/in/v..._gusset_01.jpg
http://nhvette.homeunix.com/ftp/in/v..._gusset_02.jpg
http://nhvette.homeunix.com/ftp/in/v..._gusset_03.jpg
http://nhvette.homeunix.com/ftp/in/v..._gusset_04.jpg
PS - You think you have the area all cleaned up until you take a flash picture ... damn rust.
Oooo, yes, I know just the brackets you're talking about. This one is on the right side on mine. It's managed to rip an actual hole in my crossmember as it pulled loose. I'll have to weld a patch over the hole, and either try to reuse this one or fab a couple up out of C channel.
John
