which is better??
Old Mar 24, 2006 | 12:34 AM
isissound's Avatar
isissound
Cruising
Default which is better??
in a 78 vette which is better an L48 or L82 and whats the difference?
Old Mar 24, 2006 | 12:36 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
L48 is a base engine. L82 is the upgrade engine, Forged pisons, higher compression, 2.02 valves
Old Mar 24, 2006 | 12:49 AM
Greg's Avatar
Greg
Just another Corvette guy
.....and about 45 horsepower.
Old Mar 24, 2006 | 01:02 AM
rihwoods's Avatar
rihwoods
The L-82 is the "performance" engine...more importantly...forged steel crank,pistons and 4 bolt mains...whereas,the L-48 is a two bolt block...both good engines,though...
Old Mar 24, 2006 | 06:54 AM
kaamacat's Avatar
kaamacat
Here is a link that has a few nice sublinks (on the left side) about the engines. I do like the internals of the L82 better, but, I used to own a 78 (new) and never had any issue with engine. (only "problems" actually were the A4 ac unit which were not all that reliable, and the window switchs). Mine had the L48 with all options.....
http://www.vettefinders.com/78registry/specframe.htm
Scoot over to the ENGINE COMPONENTS area on the left, very nice description.
BobR
Old Mar 24, 2006 | 11:41 AM
kdf1986's Avatar
kdf1986
Hello,
The basic answer is in the horsepower of the two engine types.
The L-48 is the base engine with 185 hp.
The L-82 is the high output engine with 220 hp.
kdf
Old Mar 24, 2006 | 04:11 PM
Scottys78's Avatar
Scottys78
Old Mar 24, 2006 | 08:20 PM
dgruenke's Avatar
dgruenke
Even though the L-48 has less horsepower, I think that it has slightly more torque.
Old Mar 24, 2006 | 09:32 PM
FOLDNTOP's Avatar
FOLDNTOP
From: Oakville ON "Real Corvettes have folding tops..."
My friend and I each had 1977's in 1979. Mine was an L48 Auto His L82 Auto. In heads up drag race I would beat him by 3 to four carlenths out of the hole. At the line I would only have him by a rubber bumber.
His as 3:55 gears mine was 3.08. I believe the L48 ahd more torque. He always hated getting beat by the L48. Another difference was the L48 ahd the turbo 350 trans while the L82 had the turbo 400 trans.
To which is better??
