Hazzard Relay
Old Mar 27, 2006 | 07:37 PM
Turtlerok's Avatar
Turtlerok
Default Hazzard Relay
I found this out the hardway... I had turn on my hazzards by mistake and some some reason it didn't flash my turn signal lights but it was enough to drain the battery and not start. And when the hazzards were on it cause the turn signals not to work, which is correct according to the user guide, but boy did I thought I pinched a wire somewhere.
Does anyone know where the hazzard relay is on a 75 stingray? And what the part is or a replacement I would need, or could an auto store match it up for me? Or even if this sounds like a relay issue, The turn signals work correct and the brakes are fine also.
Thanks in advance,
Old Mar 27, 2006 | 07:49 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I don't know if it is the same on the 75 or not, but on my 70, I have to flasher relays. You can pick them up at Autozone. One is on the upper corner of the fuse panel and the other is just behind the passengers side dash panel. You will have to lay in the floor to get at both of those flashers.
Hope this helps.
Old Mar 28, 2006 | 02:57 AM
RHD '68 L89's Avatar
RHD '68 L89
The hazard flasher can is the one on the fuse box. the normal indicator flasher can is under the passenger dash. Don't know why they put it way over there....
To Hazzard Relay
