thanks to being small ( it does have its good points at times)
i can undo my speedo cable with relative ease at the
speedometer itself.
what im wondering is
can i just slide the cable out, clean and lube and replace all from under the dash end? or do i have to disconnect and remove?
thanks in advance
by the way going to be nice enough to show it off at work tomorrow here in NJ and im looking forward to the drive in.
On my 78 SA the access to the cable where it hooks to the speedo itself was a real PITA and a tight squeeze. Push back towards the rear end of the vette on the clip pull on and the entire cable will disconnect from the speedo. Also if you have cruise disconnect from the transducer and remove the inner cable from under the dash. Once inner cable is removed it can be lubed, recommend not to over lub it. Used a grafite grease myself. Reinstall inner cable, reconnect to speedo, reconnect to cruise transducer and you should be good to go. Still have sore spots on my hands but speedo works great. Enjoy the experience!
When I did mine I unhoked at spedo and pulled the cable out (no cruise) greased it and slid it back in. I still had to jack up the car and disconnect it at the trans to get it to seat correctly.
thats what i needed to know, i also dont have cruise and with my small hands i was able to reach up and disconnect the speedo cable with ease
i just wanted to make sure i could attempt it all from up top first.
looks like a job for tomorrow evening after i get home from work.
i would just but a new cable and a tube of ''cable eze'' its in the corvette central catalog,, then when it comes squirt the cable lube in there ITS NOT GREASE!!! inner cable of yours could be fraid
Carl
good point. if its fraid when i pull it out it will definitely
get replaced.
OTOH if its not fraid and looks good its getting a lube job
and getting reinstalled.
