rust proof enamel?
Old Apr 1, 2006 | 07:15 PM
onaqwst's Avatar
onaqwst
Default rust proof enamel?
so i'm in the process of taking some of my half-azzed painted parts i did last year and gonna paint them right ( i guess)....... mainly suspension aprts and i was gonna use the rust-proof enamel by krylon (sold at murrays) as a base coat then anodized base coat then color then clear..... a friend suggested i go with por15 first and get the clear por for the last step........ any other suggestions out there...... would the enamel base be as equivalant as the por enamel?......
b
Old Apr 1, 2006 | 07:42 PM
BarryK's Avatar
BarryK
only use the POR15 paint if you are painting over rust otherwise use a more standard paint.
Old Apr 1, 2006 | 07:51 PM
onaqwst's Avatar
onaqwst
no rust=no por then
i was gonna do bolts/washers/leaf spring (steel)/ nuts
there is a bare metal por15 also........ will clear por15 affect enamel (chemically/bubbles)....... if i can get items locally it would be better ....
any other clear coats that can be brushed/sprayed (rattle can).....
thanks
b
To rust proof enamel?
