1976 A/C VIR Eliminator
Old Apr 5, 2006 | 11:28 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Default 1976 A/C VIR Eliminator
I'm considering installing the above product and was wondering if anyone has first hand knowledge of it and how well it works. Also, does this require a change to 134a from r12 freon
http://www.ecklers.com/product.asp?p...dept%5Fid=1183
Old Apr 5, 2006 | 11:54 AM
mdj21's Avatar
mdj21
i have that exact same eliminator kit only i bought it from Davies corvette instead of Ecklers. it was a bit cheaper and i saved on the shipping because i was down in the Port Richie Florida area and just picked it up off of the shelf.
haven't installed it yet, but it will work with either r12 or r134a. all you have to do is adjust the pressure switch for the type of freon you want to use.
need to hurry up and do this install. summer is getting closer. i just have too many projects and not enough time combined with limited budget....
hope thid helps,
Mike.
Old Apr 5, 2006 | 12:07 PM
Jud Chapin's Avatar
Jud Chapin
hope thid helps,
Mike.
Thanks for the reply, Mike. Do you know if all the lines and compressor hose match right up or do adjustments have to be made? Thanks again.
Jud
Old Apr 5, 2006 | 01:13 PM
mdj21's Avatar
mdj21
there are two connections. one is fixed and the other rotates. the directions tell you to rotate the top untill it matches the original configuration of your old VIR. after that, your hoses should match right up.
are you going to go with r12 or r134a?
i'm going to try to do it myself using r134a, but i'm doing it in such a way that if i am unhappy with the results it will be very easy to take it to a shop and have them charge it up with r12.
Old Apr 5, 2006 | 01:14 PM
markdtn's Avatar
markdtn
I have used a VIR eliminator kit, replaced the VIR with a cycling switch for 2 customers. One was on a 68 Firebird, the other a 71 Chevy truck. Both with R134. I thought they both worked well, although both conversions were done in springtime, not sure how they work in July/Aug. I lost touch with the Firebird owner, truck owner has run it a year now. Haven't heard any complaints about it from him.
Old Apr 6, 2006 | 11:27 AM
Jud Chapin's Avatar
Jud Chapin
I've decided to stay with the VIR system. It works fine, it's just a pita to change it out. Also, I read that the A6 compressor, which is what I have on my '76, was not designed to recycle. Check this a/c forum site and my post.
http://www.autoacforum.com/categories.cfm?catid=2
Old Apr 6, 2006 | 11:37 AM
markdtn's Avatar
markdtn
My '77 and '79 Bonnevilles had A6 compressors and a cycling system. The '77 had over 250k miles on the original compressor (2nd owner, good records). The '79 ate a clutch at somewhere over 150k.
To 1976 A/C VIR Eliminator
