C3 conversions?
Old Apr 5, 2006 | 01:37 PM
bbfirebird's Avatar
bbfirebird
Default C3 conversions?
Has anyone installed a 92+ LT1, LS1, T56, etc into a C3? I'm thinking of getting a late 70s C3 to use as a donor, and I'd like to give it a more modern and more powerful engine/drivetrain. Any advice or website links at all would be extremely helpful- from what year C3 would be a good/cheap one to buy, to problems with the conversions, etc. Thanks.
Old Apr 5, 2006 | 03:35 PM
PatsLs1vette's Avatar
PatsLs1vette
Plenty of conversions on here from tpi-lt-1 ls1-ls6's ect... i had tpi first then swapped to a ls1-700r4 combo.Overall its not that bad of a conversion easier then my tpi swap,youll need motor mounts, a better fuel setup,have the pcm setup to whatyou want,no vats etc...
Old Apr 5, 2006 | 03:42 PM
68/70Vette's Avatar
68/70Vette
What about a new GM Performance Parts catalog crate engine? A ZZ383/435? Fast Burn 383? ZZ4? Ram Jet 350? 350HO? Since these engines are not computer controlled, putting them into a early C3 becomes a lot easier, I believe.
Old Apr 5, 2006 | 04:14 PM
bbfirebird's Avatar
bbfirebird
That is an option. I'm just kind of researching it now, trying to learn what I can, pricing different options, etc. If the price would be a lot less doing a ZZ383 or something instead of an LS1 or newer computer controlled engine, I could very well end up going that route.
Old Apr 5, 2006 | 05:00 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Good grief, computer control systems aren't that difficult. If you're just installing a stock engine, they're pretty easy.
Old Apr 5, 2006 | 05:18 PM
70 LS1's Avatar
70 LS1
Its as easy as connecting power and ground. The only tricky part is to figure out where to connect them.
Old Apr 5, 2006 | 06:00 PM
Kalway's Avatar
Kalway
You got your fuel injection system hooked up yet?
Old Apr 5, 2006 | 08:16 PM
PatsLs1vette
Yep a few hot wires and a few ground wires and your set,you can use a stock fbody harness and have it wired in a few hours or less.
Old Apr 5, 2006 | 09:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
In the Corvette? No. I've done plenty of FI work in other vehicles, though.
Old Apr 5, 2006 | 10:56 PM
corvettecris's Avatar
corvettecris
I think you are the first person I know of that picked out your drivetrain and then started looking for a car as a 'donor' for it! Go for it! I have been dreaming of a LS1 powered 69 for years, and the Goodguys car show at Del Mar didn't help get rid of the bug, either. There was all sorts of LSx powered muscle there.
Old Apr 6, 2006 | 07:49 AM
markdtn's Avatar
markdtn
There are many FI conversions running around. TPI the simplest, LS power the hardest. Lots of parts are available for LS conversions now. Go for it!
Old Apr 6, 2006 | 11:39 AM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
http://forums.corvetteforum.com/show....php?t=1154326
Here's mine and it's for sale and I will consider trades as well.
FYI scroll down about halfway through the thread for all the pics. Sorry she is dirty as hell I have since cleaned her up.
To C3 conversions?
