Wheel well coating..?
Old Apr 10, 2006 | 09:06 AM
1970-Bronze's Avatar
1970-Bronze
Default Wheel well coating..?
Well, I am in the process of scraping off 25 year old under coating from my wheel wells.
I would like to coat them with something and I'm looking for suggestions?
- Primer and semi gloss?
- I don't wat to do them in POR 15.
Old Apr 10, 2006 | 09:10 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
why not go withthe zeibart undercoating
Old Apr 10, 2006 | 09:21 AM
CGGorman's Avatar
CGGorman
Yes, you should coat them. The undercoating help prevent damage to the paint and glass from thrown stone/pebbles. Without the undercoating, you can get little "stars" in the paint. It also help with noise.
Old Apr 10, 2006 | 11:16 AM
1970-Bronze
Ok, well the car is in pieces right now so I need something I can aply.
I'd like to use something "thin".
Old Apr 10, 2006 | 11:22 AM
sweethence's Avatar
sweethence
the undercoating comes in a spray can these days, so you can make it as thin as you like
Old Apr 10, 2006 | 02:21 PM
76custompaint's Avatar
76custompaint
Truck bed liner... You can make it as thin or thick as you want and it's pretty darn tough..
76CustomPaint
Old Apr 10, 2006 | 09:46 PM
Emeightch's Avatar
Emeightch
OK, so I have to ask. What's wrong with the POR 15 idea before I do it?
Old Apr 10, 2006 | 09:49 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I think it whould look like **** if you painted it on. Rubberized under coating should do they trick and it is easy to use and looks pretty good.
Old Apr 10, 2006 | 09:52 PM
82MDVette's Avatar
82MDVette
POR15 can be thinned and sprayed on. It should be alot more durable.
Old Apr 10, 2006 | 09:55 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
If you did this it would be fine. But most people don't have a spray gun. And I wouldn't spray por 15 through my gun.
Old Apr 10, 2006 | 10:13 PM
82MDVette's Avatar
82MDVette
From Por-15 website:
SPRAY APPLICATION:
Use 30-35 lbs pressure for normal gloss. Reduce pressure for lower gloss (20-25 lbs). Thin only with POR-15 Solvent, if necessary, but do not thin more than 5%.
TO TOPCOAT A FULLY CURED POR-15 SURFACE:
Wet sand with 600 grit until gloss is dull, then paint, or use POR-15 Tie-Coat Primer directly on the cured POR-15 surface, then topcoat as desired. NOTE: Never topcoat a POR-15 surface that hasn't dried, as this will ruin the coat already down.
Use POR-15 Solvent or lacquer thinner for cleanup, which must be done before POR-15 dries. NOTE: Organic vapor particulate respirators, NIOSH/MSHA approved, must be used when spraying POR-15.
Old Apr 11, 2006 | 12:02 AM
cchristo's Avatar
cchristo
If you don't put a shock absorbing coating in there, you will get stars on top of your wheel wells. I've have one on each side and I heard them happen!
Looks like the previous owner scraped whatever used to be there off.
When I paint her (hopefully next year) I am actually thinking of gluing foam up in there. Probably use some sort of semi-permanent spray glue and the type of foam used in camping mattresses.
Not sure yet, but I know I don't want to go through all the trouble and expense of painting just to get it chipped from the inside out!
Old Apr 11, 2006 | 12:06 AM
GaryZ's Avatar
GaryZ
You are right! A light coat will do. At least on the top part above the wheel. Rocks will damage the paint from tire throw. Little stars in the paint. I know. zzzzzzzzzzzzzzz
To Wheel well coating..?
