I love my Qjet
Old Apr 12, 2006 | 09:17 PM
SpcCox's Avatar
SpcCox
Default I love my Qjet
d so long to do it.
Old Apr 12, 2006 | 10:11 PM
IMA 66's Avatar
IMA 66
that is one of the coolest things when those big ole secondaries open up
shafrs3's Avatar
shafrs3
I've always knew they were a better carb, delivering fuel more precisely.
Old Apr 12, 2006 | 10:58 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'm forever telling people that if you're going with a vacuum secondary carb, a Q-Jet is better than a Holley,..easier to tune, meters more conistantly throughout, flows plenty (750 cfm), and better mileage.
Then the same people look at me like they're waiting for a punch line.
The Holley has one advantage,..larger fuel bowls, but that can be overcome with a larger needle/seat assy and some other tricks.
Old Apr 13, 2006 | 05:24 AM
Kalway's Avatar
Kalway
Qjets aren't vacuum secondaries, though...
Old Apr 13, 2006 | 05:53 AM
fl_rider's Avatar
fl_rider
Default News to me.....
Maybe you could illuminate us all.
http://www.tocmp.com/manuals/Carbs/R...20complete.pdf
Here is some interesting reading on the operation of the Q-Jet.
Pages 11 and 12 describe the vacuum operation of the air valves for the secondaries.
Old Apr 13, 2006 | 11:48 AM
73, Dark Blue 454
Of couse a q-jet is a vacuum secondary carb,..the butterflies on top the secondaries sense the vacuum signal and meter the air and fuel accordingly. How quick or slow it opens is very adjustable,..there's a little set screw on the passenger side of the butterfly shaft. If it opens too fast, she'll bog,..to late, poor performance,..just right will put a big smile on your face.
Lack of this knowledge is the biggest reason people struggle with q-jets.
A mechanical secondary carb uses throttle linkage/movement for opening and metering of everything in the primary and secondaries.
Old Apr 13, 2006 | 02:46 PM
gonzo14's Avatar
gonzo14
Q-jets rule!! THEY RULE!!!
Gonzo
Old Apr 13, 2006 | 04:25 PM
Kalway's Avatar
Kalway
I'm hoping lars will chime in and back me up on the q-jet not being a vacuum secondary...
Old Apr 13, 2006 | 04:41 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
They are somewaht mechanical, but they only open up based on what the engine can use at the rpm and vacuum signals.
Lars is the expert...he can explain it better
I love my Q-jet. For years I thought Holley was the only way to go....know better now. Better low and mid range, throttle reponse and economy
I am fortunate Lars tuned mine about a month ago.
Old Apr 13, 2006 | 05:16 PM
SpcCox's Avatar
SpcCox
We tuned that holley up and down and just couldn't get it to do anything major, no matter what we did. It just wouldnt respond. I don't know whether someone else did the tuning on the Qjet but to my knowledge it hasn't been out of the box in at least five years...Bolted right on and I haven't gotten enough of it since.
Old Apr 13, 2006 | 05:32 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Old Apr 13, 2006 | 06:36 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
The bottom butterflies are mechanical. The top butterflies, which also pull up the rods and allow fuel to flow operate with vacuum.
Old Apr 13, 2006 | 06:41 PM
The_Dude's Avatar
The_Dude
Here is an explanation from Lars.
http://forums.corvetteforum.com/show...post1554248173
Old Apr 13, 2006 | 07:01 PM
SmokinBBC's Avatar
SmokinBBC
So how do you adjust the butterflies with this screw?? Is there a procedure, or is it just hit and miss?
Old Apr 13, 2006 | 07:46 PM
73, Dark Blue 454
Some people call a quadrajet an "air valve",..that's fine although the little diaphragm on the side of your carb that controls the upper secondary butterflies (air valves) open and close based on vacuum. Also,..some would call air being sucked into an engine "vacuum".
Not an arguement that will solve anything (I must have too much time) but here's some support for my side:
http://www.hemmings.com/index.cfm/fu...article_id/498
http://www.carcraft.com/howto/57178/
http://www.arkansaspontiacs.org/tech...ockyQ-jets.htm
But we agree in principle,..love me some q-jet!
Wes
Old Apr 13, 2006 | 07:47 PM
windsoreight's Avatar
windsoreight
I love mine to, It holds the shop door open when my hands are full
Old Apr 13, 2006 | 08:53 PM
Fevre's Avatar
Fevre
To I love my Qjet
