Diff plug removal
Old Apr 18, 2006 | 08:53 AM
turbo78vair's Avatar
turbo78vair
Default Diff plug removal
Put the rear up on the Rhino ramps last night with hopes of changing the rear lube after a short road run to get it warmed up. Well, I can see it, can feel it, but didn't have any success with my tool inventory in getting the plug out. It's a square 5/8 inch plug, but as you're aware, space is limited as to tool swing window.
What do you use?
I've got the new suction gun and new GM lube and additive ready to do the task, but can't get the plug out. Had thought some overnight about maybe a metric box end would catch corners of the 5/8 plug. Don't know!
Well, have to spread some lawn fertilizer right now, so will check back later.
Gary C - '78 Pace Car
Old Apr 18, 2006 | 09:02 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Mine was too rounded to work, but I've heard that a 20 or 19 or something MM socket and then a long extension and a U-joint make a quick removal of that plug. I got mine out the first time using a crescent wrench - took a long time with the small window of opportunity.
Old Apr 18, 2006 | 11:14 AM
Warhead's Avatar
Warhead
Take the spare tire carrier out
Old Apr 18, 2006 | 11:23 AM
lowbuck72's Avatar
lowbuck72
I used a large crescent wrench inserted perpendicular to the square nut. Then I inserted a large screwdriver into the hole on the handle of the crescent and it came right off. Grab one of your wife's shampoo bottle pump tops and insert a piece of fuel line onto the pickup. You can insert the line into your diff and use the pump to empty it out. Make sure you clean out the pump pretty well before you put it back onto her shampoo bottle.
Old Apr 18, 2006 | 11:24 AM
chevylit's Avatar
chevylit
Had mine out last Saturday, used 3/8 drive 12 pt socket on a long
extension. Once it breaks loose it comes out very easy.Even using
ratchet You can only get about 1/4 turn at a time.
Old Apr 18, 2006 | 11:43 AM
kdf1986's Avatar
kdf1986
Hello,
I found that by taking off the spare tire carrier, and the top of the clamshell that I had enough room to move around and to get to the bolt to remove it. I fought with this for about 1 hour trying to get enough leverage to get to the bolt. I removed the tire carrier in around 30 minutes, and had the bolt out 5 minutes later.
You can see from the photo how much room you gain.
kdf
Old Apr 18, 2006 | 11:47 AM
PRNDL's Avatar
PRNDL
spare tire? If the rear is up on ramps I presume both rear tires are still on the car ?? You get much better access by removing the passenger side rear wheel.
Old Apr 18, 2006 | 01:22 PM
ruby76's Avatar
ruby76
Originally Posted by kdf1986
Hello,
Good point. I ended up doing this way the 2nd time - I just forgot about it!!
Old Apr 18, 2006 | 10:55 PM
turbo78vair
Thank you all for the many tips. I will give it a go tomorrow. Sorry for the delay in responding, didn't think I'd received any replies.
Had a nice ride tonight - about 30 miles - life is good.
To Diff plug removal
