Installing an AMP
Old Apr 18, 2006 | 11:15 AM
the_lane's Avatar
the_lane
Default Installing an AMP
Hi,
I want to use my IPOD in the car but do not want to change the stock head unit (original crappy am radio)
Is it possible to install an AMP independently and run the ipod directly into it (and add a couple of new speakers in the back)???
Old Apr 18, 2006 | 11:29 AM
onaqwst's Avatar
onaqwst
yeah u can but u need a head phone jack to rca converter thingy.... not sure on the overall power that the head phone jack can make throught the rca's but if it's good enough u can use it..... meaning that the frequency/volumn is not too much/too little........ back when i had my hooptie, i rigged up a walkman to an amp and it worked great.....
b
Old Apr 18, 2006 | 01:32 PM
baja216's Avatar
baja216
Originally Posted by the_lane
Hi,
What about one of those FM transmitters/modulators you connect to the ipod?
Old Apr 18, 2006 | 02:33 PM
mod81's Avatar
mod81
hey everyone, i do the same thing with my ipod...i will tell you that right now i have the monster cable fm transmitter for my ipod (80$ and worth every cent!). I kept my stock head unit and i have a 10" JL sub with a 400W Kenwood amp pushin it...sounds great. You lose very little with sound with a good transmitter. so if you want go ahead and run it right to your amp, but man just save yourself a lot of work and buy a good monster cable transmitter.
Old Apr 18, 2006 | 03:48 PM
Jerry Curl's Avatar
Jerry Curl
Monster cables are a rip off.
Old Apr 18, 2006 | 04:07 PM
tyancey00's Avatar
tyancey00
just run an aftermarket radio in the box behind the seat and do it up!
Old Apr 18, 2006 | 04:14 PM
JoeRags's Avatar
JoeRags
not if your looking for quality sound..... I've got a $800 pair of 4 gauge speaker wires for home B&W speakers... worth every penny.
as far as running the ipod to an amp... dont do it. you need a pre-amplifier inbetween the two. I'd say your best choice is an FM transmitter, but then again.... does your radio have FM? or only AM?
Old Apr 18, 2006 | 04:33 PM
SULLY_PA's Avatar
SULLY_PA
I thought I saw a post around here in which someone said they had one directly plugged in and it worked fine
Old Apr 18, 2006 | 04:45 PM
JoeRags's Avatar
JoeRags
yea, it would work... but your not going to get NEARLY as much amplitude out of it had you run a pre-amp.... problem is, the ipod headphone output at max volume is pretty much equal to a line level output... for example, you have a modular stereo at home consisting of a preamp, power amplifier (with no volume ***** or anything) and a cd player. if you took the cd player and plugged it direclty into the amp, thats what you'd be doing with the ipod. There would be pretty much 80-90% of the amplifiers power output potential at rest... no way to utilize it.
Old Apr 18, 2006 | 05:31 PM
mod81's Avatar
mod81
its not monster cable(s) its one wire from the cigarette lighter to your ipod,...yes, its a product of Monster, however its just a transmitter, and since i bought about 3 or 4 for 40 bucks and a 1 for 50 and returned every single one for not working at all...i think that is grounds for saying that it isnt a rip off
Old Apr 18, 2006 | 05:54 PM
SULLY_PA's Avatar
SULLY_PA
gotch ya'
Old Apr 18, 2006 | 06:54 PM
78pacer's Avatar
78pacer
Eight HUNDRED Bucks??.....for 4 gauge wire?...........Damn!
Old Apr 18, 2006 | 07:27 PM
JoeRags's Avatar
JoeRags
hahaha, thats nothin... I got them for MUCH less from a friend in the business... check these out, $3000 for a 12ft pair.
http://www.monstercable.com/productPage.asp?pin=17
but when you got speakers that cost $50k, you bet your *** you'd spend that much on wires.
Old Apr 20, 2006 | 05:36 AM
the_lane's Avatar
the_lane
Hi,
My Radio is only AM so, FM transmitter not an option (they are also illigal in the UK!!)
Has anybody done an AMP install? Do you have to hook it straight up to the battery?
Old Apr 20, 2006 | 09:45 AM
JoeRags's Avatar
JoeRags
yes, an external amp will need to be connected directly to the battery with a fuse in line. Again though, you need some sort of source unit to feed the amplifier. I suggest you get yourself an aftermarket head unit and either replace your original (will require cutting) or mount it behind you in a makeshift box or something. With a new headunit, you could even get away without buying an amplifier.
Old Apr 20, 2006 | 09:53 AM
Jerry Curl's Avatar
Jerry Curl
Heh... I used to be like you. But Ive read several articles in time past about Monster's over-inflated prices. I also spent some time experimenting with a couple different brands on my home theater setup.
You are paying for a name only. Buy hey, I guess some people have too much money.
To Installing an AMP
