St. Jude Donor '03-'05-'06-'07-'09
Rear Spring Recomendation...
I know another one...did the search, read the posts and archives nothing seemed to answer my question. Read about the 7 and 9 leaf as well as the composite springs..
Have a 72 convertible, base 350 auto. plan on keeping the car stock or stock looking as much as possible. Car came from GM with a 9 leaf, currently has a 7.
Want a nice, firm ride, good handling and correct height.
Recomendations!!!!
thanks
I just did a complete suspension rebuild to my '69 and I went with the VB&P 360lb. monoleaf. I've been very happy with it but almost wish I would have went a little stiffer. I think it looks so cool with the monoleaf and spare tire carrier removed.
Here is a link to a picture but be warned it is huge so I wouldn't click on it unless you have high-speed access. I left it large so you can zoom in on the rear suspension but it's a little dark. Oh and nevermind the half naked girl sitting on the back.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Recomendations!!!!
thanks
just replces my rear, fron t next, went with the 9 leaf, a littel more arch, and i like to ride high in the saddle, that and KYB's and VBP strurods with forged ends. i use mine as a highway runner so i like the 9 leaf's feel, back end went from trying to beat the front around corners to tucking up nicely, if yolu want the performance stick with the 7 though stiffer spring
Here is my 69...recently installed a Guldstrand 7 leaf (1 1/2" shorter than stock) and Bilstein Sports...the ride is firm and much improved over the TRW composite spring on the vette when I purchased it..
The issue I had with the TRW was a bounce/lope experienced when hitting a bump at speed..not the case with the 7 leaf..
You can adjust height up/down with either long or short bolt kits...
One advantage is that spring is 1 1/2" shorter than stock 7 leaf which gives you more tire clearance at mounting bolts..the other for me is this spring is about 50# stiffer than stock 7 leaf..(got a 502 and torque at 570 Ft Lbs)
Be sure to call them for info....ask for Bobby..
Rich
Originally Posted by rihwoods
...USMC 1962-1966...that's why I like Fathom Green..
i was 86-95
Ahh one of Uncle Sams Misguided Childrens, my cousin just joined up, tried to get him to join the cav, told him we get to wear stetsons and spurs, would'nt have it though, he wanted to be special
Recomendations!!!!
thanks
Look at this thread. Lot of good info. http://forums.corvetteforum.com/show....php?t=1360447
I swapped out the front and back springs recently with a composite rear and new fronts from VPB.
Before
After
If you go composite, you gotta get the right shocks
